4.3 to 4.8/5.3 again
Old Aug 5, 2012 | 11:19 PM
silverado.408's Avatar
Default 4.3 to 4.8/5.3 again
Yep yep i know another 4.3 swap question. Newish to this site but im on lsxnation and ls1tech. Anyway truck is rcsb classic 07 silverado. I have been looking all around but cant get a solid answer. Wiring harness issue Im staying with DBC over all I think its better. Which harness do I need. 03 and later or 99-02 any ideas thanks.
Old Aug 5, 2012 | 11:52 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Re-wire your Existing harness for a cable operated set up using a Van Wiring schematic from a similar year. Then have the computer flashed accordingly for the van operating system and Tune accordingly.
Old Aug 6, 2012 | 06:27 AM
TXSZ66AVLANCHE's Avatar
As much as I enjoy building harnesses...I'd have to disagree. Unless you have modified engine harness before and have access to schematics just save yourself the headache and buy a harness.
Old Aug 6, 2012 | 12:37 PM
ok im just gong to buy a harness but are there any issues with the fact my truck is a 07 with a dbc and im going to stick with that. And if so what do I need. But from my understanding I dont need anything just a v8 DBC harness and a reflash ecm Right ? All the fuses and crap should still line up the same.
Old Aug 6, 2012 | 11:32 PM
1FSTMAX's Avatar
if you have an 07c, you need to get a donor harness from a 05, 06 or 07c. There were some changeschanges from 03-04. Also when you get your harness get the tac module, and gas pedal from the same truck as the harness.
pewter00
11
Oct 20, 2023 05:40 AM
SLOPONY
11
Sep 24, 2015 02:47 PM
chvy=power
Aug 31, 2015 10:51 AM
Blackrat48
Jul 12, 2015 07:28 PM
