4.10 Gears.
Old May 27, 2003 | 06:18 PM
JSmith's Avatar
Default 4.10 Gears.
What brand ring and pinion gear set are you guys running? I want to go with 4.10's but I don't want to pay the $587 for the GM gear set! Who makes a good reliable gear that isn't noisy?
Old May 27, 2003 | 06:33 PM
hyper's Avatar
Default Re: 4.10 Gears.
havent had a problem with my 4.10 Richmonds. but they are noisy every once and awile
Old May 27, 2003 | 06:36 PM
Don't get the Genuine 4.10 gear set then, They whine a whole lot but they are holding up quite nicely so far with the Eaton posi!
Old May 27, 2003 | 07:58 PM
FILE's Avatar
Get yoursellf some Motive Performance. That is what I have on my extended and they are quaet as cat. I am not sure how true this is but I hear "Gears don't whine, bad installation does".
File
Old May 27, 2003 | 08:29 PM
I've got about 60k on my richmond gear 4.10 no whine yet.I agree proper install and lash setting is a must. Jim
Old May 27, 2003 | 10:58 PM
JSmith's Avatar
I agree on the proper lash and install but the gears still whine depending on the cut. I guess the new GM gears have a 5 angle grind. I'm still not paying $587 for a set of gears! The install is going to run me about $320.
Old May 27, 2003 | 11:17 PM
a friend of mine has precision and i've never heard a noise from them at all
Old May 28, 2003 | 09:08 AM
bigguy75inches's Avatar
call randy's ring and pinion! 1800-292-1031
Great guys up their. I called to price new gears for front and back (4wd) as well as an eaton posi.
at first their price was high. i just said hey look, i can get same stuff for alot cheaper.
he said well. how about this. and quoted me a price about 200 bucks cheaper! He even though in discounted shipping. just dont let them run over ya and be nice. they can really help.
Old May 28, 2003 | 09:36 AM
L-EATER's Avatar
11 Second Truck Club
I am with big-randy's r and p is the only place to get rearend parts. They have good service, are knowledgeable and sell quality stuff. I bought a set of 3.73 Yukon brand gears from them for my street rod and they set up easy with NO noise at all. A lot of aftermarket gear sets whine because of the way they are cut so be aware of that.
Old May 28, 2003 | 09:54 PM
Ajax's Avatar
Having just gone thru this last week, it has nothing to do with the gears themselves. It is how they are set up. There are 2 grind & 5 grind gears. 2 grind gears are biased towards the toe and heel of the ring gear, and 5 cut gears have no bias. If you buy 2 grind gears and the installer tries to set them up like 5 grind gears you will have noise. You will get noise from 5 grind gears if they are set up with bias towards the toe & heel. You just have to know which kind you have, and make sure your installer knows how to set them up correctly. I bought my gears from Power Train Truck & Auto Parts. Gears were $159.95 plus shipping. They are GM 2 cut gears, and work great on my truck now that I know the difference in grinds. They are great guys to deal with. They also sell the install kits for our trucks. Their # is 1-866-589-GEAR.
