380 offset stroker engine
Old May 21, 2003 | 04:26 PM
fast2001's Avatar
Default 380 offset stroker engine
Guys,
What do you think about this setup. I am building a 380 offset stroker engine. I am grinding the journals on my stock LS1 crankshaft to get 3.71 inch stroke, this is the most you should go according to Futral Motorsports. I will be using Eagle forged rods and Diamond 4.04 forged pistons with a C2 MTI camshaft. The heads are 6.0L stage II going through a TCI 3000 stall on 3.73 rear end. I should have this completed in the next couple of months. I will get it dynoed at thunder racing. So stay tuned!!!
Old May 21, 2003 | 08:09 PM
GREGGO's Avatar
Default Re: 380 offset stroker engine
How much you planning on RWHP wise? I would go with a bigger stall though. Other than that, it sounds great! Good Luck!
Old May 21, 2003 | 08:15 PM
gonzo 6.2's Avatar
Hey 2001
If you dont mind me asking what will you been the rotating assembly?And how many cubes will be gained with just the stroke?Will there be any clearance issues to deal with?
Old May 21, 2003 | 08:22 PM
fast2001's Avatar
Greg,
I am hoping to get around 420 rwhp or better. I will find out soon and I will post the numbers on the board. The extra stroke will get me 10 cubic inches and there should not be any clearance issues because I am using a stock LS1 crankshaft.
Troy
Old May 21, 2003 | 08:51 PM
Banned
just because you are using the stock crank doesn't mean you wont have any clearance issues, clearance issues come from the extra stroke moving the rods down farther and out around farther, you very well may have some issues, you also may not. i would definatly go with a bigger stall with that motor and cam, i would even go with a bigger cam. i am expecting 420+ rwhp from my new motor and i'm not running 380 inches, most of the 383 strokers are getting 440-470 rwhp with similar cams. what block are you using to get the 4.04 bore?
Old May 21, 2003 | 09:02 PM
fast2001's Avatar
Matt,
There should not be any clearance issues because the stroke is only 3.71 inches. I am using a 6.0L iron block and boring it to 4.04 inches.
Troy
2500ZL1
Jan 25, 2016 06:30 AM
black00chev
Aug 12, 2015 01:56 PM
DONTH8
Jul 26, 2015 06:59 PM
ChevyLee
Jul 10, 2015 10:56 PM
jrplz
Jul 9, 2015 12:07 AM
