370 top end
Old Oct 19, 2015 | 05:55 AM
1slwgto's Avatar
I'm trying to as close as I can to 500 wheel then spray on top. So which ever was is more efficient to get me there.
Old Oct 19, 2015 | 08:45 AM
Vortec350ss's Avatar
500 to the wheels will require a lot of cam and a great set of heads... If you go cathedral think a good set of CNC 225CC heads. The LS3 heads could get you there as well.
Chevrolet Performance LS3 CNC-Ported Aluminum Cylinder Head | Chevrolet Performance
Old Oct 19, 2015 | 09:59 AM
1slwgto's Avatar
Those are good heads for the price. I've been looking at the tsp ls3 ported heads. I was also going to get a cam speced out for me. It's a toy now so not to worried about a dd cam.
Old Oct 19, 2015 | 10:20 AM
USMCvet0311's Avatar
Hmmm... not sure thats correct. I have 69cc heads (LS3's stock are 68) with 3.2cc valve relief pistons and its a 10.2 compression motor.
You really cant go wrong with either option, but if I was building NA only and had a big budget I would choose a nice set of cathedrals. With a smaller budget I think the LS3 head starts to look really attractive. It likely wont quite have the snap of a nice cathedral, but it will pull hard as hell from your mid range on up.
I had my rotating assembly spec'd for 11.5-1 and heads worked to get that compression.
Old Oct 19, 2015 | 12:11 PM
gamble686's Avatar
Originally Posted by 1slwgto
Could you explain a little more ?
Basically we can make 100 different suggestions, but without a price range it is mostly a waste. Also compression ratio will make a big difference in choosing a good head. For example if you want 11.5:1 you will want a cathedral head such as some 243's that have been worked and milled. If you want lower compression around 9.5:1 then it opens up the choices. Also if you get square port heads keep in mind it changes your entire intake manifold setup. Also if your cam is only good to .600 lift there is no reason to get heads that are good to .675 or if your cam goes to .650 then you need heads to match.
Old Oct 19, 2015 | 01:20 PM
1slwgto's Avatar
I'm trying to get heads under 2k , 800 for cam and springs, plus I'm going with a new intake manifold due to having a stock 99 intake right now.
Trying to keep compression above 10.5
pewter00
11
Oct 20, 2023 05:40 AM
legerwn
56
Nov 15, 2015 10:21 PM
ice17
Sep 22, 2015 05:18 PM
twake_410
Sep 21, 2015 10:36 AM
xtrooper89
Sep 21, 2015 06:03 AM
