370 In and Running
Old Mar 3, 2008 | 08:34 PM
  #21
Dark Halo's Avatar
Originally Posted by dirt track racer 81
specs are:
4.030 6.0 block
stock crank
hbeam rods
mahle flat top pistons
mahle file fit rings
241 ported heads
.040 head gaskets
230/226 dur cam .597 .563 lift
the intake it a professional products 85mm intake and 85mm throttle body that i had to port out..it necked down like the stocker did
what are the cc's of the heads in order to net 10.3 compression
Old Mar 3, 2008 | 08:37 PM
  #22
dirt track racer 81's Avatar
67cc http://www.c5frc.com/calculators/Com...Calculator.htm
Old Mar 3, 2008 | 08:39 PM
  #23
if that wrong let me know
Old Mar 3, 2008 | 08:46 PM
  #24
bluecajun5.3's Avatar
11 Second Truck Club
thats whats up tyler!
looking good bro
Old Mar 3, 2008 | 08:48 PM
  #25
Dark Halo's Avatar
I dont know if it is wrong I was just considering a 370 if this motor needs any work because the pistons cost the same, and I was looking at the patriot 68cc heads.
Old Mar 3, 2008 | 08:56 PM
  #26
thanks lance..
halo..is your sig is that what you plan on building or do you already have ls6 heads?
Old Mar 3, 2008 | 09:47 PM
  #27
Dark Halo's Avatar
thanks lance..
no I already have the LS6 patriot stage 2 heads but they are on my 02. My new build is for a 92 step side
Old Mar 3, 2008 | 09:49 PM
  #28
Dark Halo's Avatar
also if you are wondering about the compression that it what the guys from patriot came up with. he told me that the 644 cc head would bump the compression 1 point
Old Mar 4, 2008 | 06:02 AM
  #29
Wilde Racing's Avatar
How do I change this text
Hell, I even got Amber out to help me put in.
Looks like she did most of the work
Damn, I'm jealous. You started your engine build way after I did and you are done.... I haven't even got my engine back from the machine shop yet!!!
I'm glad to hear everything is running good (once you get your o-ring leak fixed)
Old Mar 4, 2008 | 06:34 AM
  #30
Dark Halo's Avatar
I was also going to ask is the .040 head gasket size stock size?
