370 In and Running
Old Mar 2, 2008 | 09:32 PM
Phantom's Avatar
11 Second Club
the motor looks purdy. i was pretty jealous. when my truck grows up, i want it engine bay to look like his...minus the burnt ****
Old Mar 2, 2008 | 09:35 PM
dirt track racer 81's Avatar
i was putting my coil packs back on and i got them switched..i had to switch back since the wires, connections, and coils were melted...on front two coils
Old Mar 2, 2008 | 10:01 PM
regency's Avatar
so whats the specs on the motor????? im still undecided what to do with my new fresh 4.030 block!!!
Old Mar 2, 2008 | 10:58 PM
silveradokidd_4518's Avatar
awesome man!
Old Mar 3, 2008 | 10:58 AM
budhayes3's Avatar
PT's Slowest Truck
Very nice, what brand intake is that?
Old Mar 3, 2008 | 11:15 AM
20002wdchevy's Avatar
14 Second Truck Club
Looks sharp. I was wondering about that TB. Did you do that yourself or is that a self part?
Old Mar 3, 2008 | 08:07 PM
specs are:
4.030 6.0 block
stock crank
hbeam rods
mahle flat top pistons
mahle file fit rings
241 ported heads
.040 head gaskets
230/226 dur cam .597 .563 lift
the intake it a professional products 85mm intake and 85mm throttle body that i had to port out..it necked down like the stocker did
Old Mar 3, 2008 | 08:08 PM
welp heres some news ..today i let it run for a while then put a few easy miles on it..then today i changed the oil and took it out for a little cruise i drive almost ten miles and deside to lay into it a bit. i just take it up to 5k and it falls on its face and starts running like **** and is tryin to die so i pull over and i can smell gas and fuel is pouring from underneath..its gettin dark i start messin with the injectors and the back injector i wiggled it and fuel spurt out..so i called my dad and had him get some tools to take the fuel rails off and the 0-ring had a small cut in it..this about turned out like last time i put my motor in ..fuel injector popped out and the truck caught on fire..anys ways got a new oring on it and went and drove some more and finally took it to 6000+..felt good..i still think ill need the 200 pills to hit 11's though
Old Mar 3, 2008 | 08:11 PM
regency's Avatar
what kind of compression??
Old Mar 3, 2008 | 08:26 PM
i think its around 10.3
