342 vs 410
Old Dec 8, 2003 | 10:29 AM
Maree's Avatar
Default 342 vs 410
Hey guys I have a 03 tahoe with 342 gears and it is lazy down low, It runs a 16.05 @89 on my g tech. I was wondering what gains I would have if i went to 410s? I do not even go into third gear, but it pulls hard when it gets into its power band. I was just thinking that getting it into its power band faster might help. Thanks in advance.
Old Dec 8, 2003 | 10:45 AM
Flyer's Avatar
http://www.gafba.com/calculators/ringgear.asp?mode=ntr
There is a calculator for gear changes. Put your tire size in and your current gear and the gear you want to check out and it'll tell you what your revs would be at what speed. Leave it at the default tranny setting, that it the correct one for the 4L60e.
Old Dec 8, 2003 | 11:37 AM
2ksleeper's Avatar
I believe you would probably gain .5 sec as long as you dont have any traction problems. I went from 3:42 to 4:10 which magnified my tractions issues. On my truck I run 28.9" dia tires and it turns 2400rpms at 70mph. If you want to improve your quarter mile times you might want to aslo look at a higher stall convertor which will get the rpm's up in the power band faster.
Old Dec 8, 2003 | 12:13 PM
Maree's Avatar
2ksleeper I was wondering the cheapest way to correct my speedometer.
Old Dec 8, 2003 | 01:16 PM
Flyer's Avatar
A programmer would do .. something like HyperTech. A bigger torque converter is a good suggestion too. Maybe a Yank TT2600.
max_ta
Nov 10, 2015 07:50 PM
Tuckin15s
Sep 23, 2015 09:35 PM
USMCvet0311
Aug 14, 2015 10:28 PM
elpyro89
Jul 28, 2015 05:51 PM
04GIBBS
Feb 21, 2007 06:44 PM
