317 or ls6 heads
Old Jun 9, 2009 | 08:08 PM
droppedchev's Avatar
Default 317 or ls6 heads
im running 317s on my 6.0 wondering if i should go with the ls6 heads or should i pull my 317s and have the machine shop build better heads with bigger valves and would it be cheaper then buying stage 2 heads
Old Jun 10, 2009 | 05:55 AM
Tootall's Avatar
317/243's are identical . . . except for the combustion chamber. Unless you're getting the Z06 243s, they're the same.
Old Jun 10, 2009 | 07:17 AM
oh alright im just going to pull those 317s and mill them down .30 bump up the compression alittle bit
Old Jun 10, 2009 | 05:31 PM
Beatdown Z's Avatar
Laid Back
Milling the heads .030 is going to put your compression at what? And the intake is still going to line up good with taking that much off?
Old Jun 10, 2009 | 05:34 PM
00ChevyScott's Avatar
Wearin' da big hat
Milling the heads .030 is nothing, and the intake will fit fine. The pushrod length is the main thing to consider.
Old Jun 10, 2009 | 06:09 PM
yeah it all lines up just gotta break out the tool to measure the pushrods should bump the compression to 10.5to1 maybe more
Old Jun 10, 2009 | 06:11 PM
i wonder if i take 706 heads off my 4.8 it will do to my 6.0 i know it wont flow as good but that will bump the compression
Old Jun 10, 2009 | 06:18 PM
Wearin' da big hat
If its on an LQ4, it'll be a lot closer to 10:1
Old Jun 10, 2009 | 06:31 PM
yea thats what it was i thinking how much you think i can mill down and still keep the 7.4 pushrods
Old Jun 10, 2009 | 06:33 PM
Wearin' da big hat
I'm gonna go with not much.
