317 heads on 5.3
Old Apr 6, 2009 | 10:56 PM
slowswb's Avatar
Default 317 heads on 5.3
i wish think getting the heads milled 40 thousands and than use 15 thousands shim gasket. whats everyone opinion on this?
Old Apr 6, 2009 | 11:04 PM
sdimer350's Avatar
why not just mill them 25 thousandths?
Old Apr 7, 2009 | 03:00 PM
5.3LJimmy's Avatar
10 Second Club
You definitely can't run a 0.015 shim gasket. With the piston being out of the hole you would have a bit of a clearance problem. Personally 0.040 is the thinnest I would go.
Old Apr 7, 2009 | 03:53 PM
white lightning SS's Avatar
What is the pourpose of starting with the largest CC combustion chamber. If you want more compression why noy use LS6 heads?
Old Apr 8, 2009 | 07:32 PM
slowswb's Avatar
i would use 243 if you could find a set for a good price and i bought a 317 heads with 25000 miles on for 50 dollars off a friend that sold his 6.0 short block and gave me a good deal on the heads. i just looking to stay at the same compression but with 317 heads but flow alot better.
Old Apr 8, 2009 | 07:46 PM
joeyc125's Avatar
11 Second Truck Club
DON'T DO IT!!!! There would be no gain to be had really. You would lose too much compression and wouldn't gain much if anything. If you want to do something get your stock heads milled and ported and you will be much better off, might cost a few pennies more but it would be worth it.
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
