300 Shot a little to much
Old Aug 18, 2003 | 03:17 PM
  #21
Default Re: 300 Shot a little to much
Talked to Art Carr transmissions,they claim that their 4L80E can stand up to 1200hp and can take full throttle shifts into 4th gear.I say I'm going for it,no guts no glory.
Old Aug 18, 2003 | 03:25 PM
  #22
Hit Man X's Avatar
Is the REAL Art Carr of California Performance Transmissions? The "Art Carr" name is used by some apparently really shitty trans builders now as they purchased the rights to his name...
Old Aug 18, 2003 | 06:24 PM
  #23
Talked to Hughes Transmissions they also said full throttle shifts into 4th are no problem with engines in the 800 to 900hp range.
Old Aug 18, 2003 | 09:48 PM
  #24
408 Stepside 01's Avatar
I talked to my buddy at whipple and he said that you can also turn on all the nessary options to run the 4L80E with out buying the tci addaptive computer. If you have Edit then you can swap tranys with out a problem. I have to ask more questions to find out the exact things to turn on. I know that it is in the trans dia. tables though.
Old Aug 19, 2003 | 02:37 AM
  #25
Hit Man X's Avatar
That is what I thought as the 4L80E is in the 1500HD, 2500, and 2500HD trucks and as far as I know they all have the same PCM. You would have to reset the 1-2 and 2-3 shift times, rpms, etc as the internal gears are different. I'd assume the plugs for both of the trannies are the same for the VSS, TCC, etc. but once again I can not be for sure. I would go take some pics of the plugs on a late model 4L80 and some of your 4L60 and compare them.
twake_410
Apr 14, 2016 09:58 PM
LSXstef
Dec 22, 2015 08:31 PM
GMCtrk
Oct 5, 2015 11:18 AM
Slammed silverado
Sep 28, 2015 06:14 PM
ice17
Sep 22, 2015 05:18 PM
