3-4 shift
Old Jun 13, 2005 | 01:14 PM
  #41
zippy's Avatar
i usually try to set every aspect of the trans settings including all the wide open and part throttle shift patterns.
Old Jun 13, 2005 | 10:38 PM
  #42
moregrip's Avatar
what a rush!
Originally Posted by Crash Dummy
I think it may be a template problem in the trans file send a E mail to HP Tuners and see if they can fix it
and I quote...
"The tables look good to me. It seemes this calibration is set to never change into 4th at high loads (you'd have to ask GM why on that one)."
Old Jun 13, 2005 | 11:10 PM
  #43
02sierraz71_5.3's Avatar
just set the value at wot or 100 tps to 256 on the 3-4 you will never see over 6k in third Ive been past 130 and had gear left in third, only reason I let off was the drive shaft started vibrating. Im assuming the 60e
Old Jun 13, 2005 | 11:24 PM
  #44
zippy's Avatar
what is your tire height grippy?
Old Jun 14, 2005 | 01:12 AM
  #45
moregrip's Avatar
what a rush!
32"
Old Jun 14, 2005 | 09:32 AM
  #46
KySilverado's Avatar
This is the point I tried to make early on.
Old Jun 14, 2005 | 09:34 AM
  #47
This is the point I tried to make early on. He is only doing 80 mph at 4600rpm in third.
Old Jun 14, 2005 | 11:01 AM
  #48
zippy's Avatar
i would set the 3-4 w.o.t. shift at 128 and scale the part throttle shifts accordingly. they are likely way off also.
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 06:27 AM
