3-4 shift
Old Jun 11, 2005 | 05:48 PM
moregrip's Avatar
what a rush!
Default 3-4 shift
what rpm do you have your 3-4 shift set up for?
Has anyone seen a value of 8192 entered in for this parameter? if so, what does it indicate?
thanks
Old Jun 11, 2005 | 06:32 PM
ZDEN's Avatar
mine is 8192 also. i believe its there so it wont shift to od at wot.
Old Jun 11, 2005 | 06:40 PM
FILE's Avatar
thanks
It's meant for it not to ever shift into 4th gear. This is also the case in the mph vrs gear table value of 255mph for the 3-4 shift. I have mine set @ 6400 rpm.
Old Jun 11, 2005 | 06:46 PM
moregrip's Avatar
what a rush!
first off, thanks.
second, at WOT mine shifts to 4th gear @4600rpm like clockwork with the 8192 setting, wtf?
Old Jun 11, 2005 | 08:09 PM
moregrip's Avatar
what a rush!
is this more like a suggestion? because mine shifts at 4600rpm WOT
Old Jun 11, 2005 | 08:36 PM
KySilverado's Avatar
Not a suggestion. Most tunes I've seen have the "don't shift into 4th" at WOT settings. Mine included. Seriously though what speed would you be doing at 4600 rpm in third
Old Jun 11, 2005 | 08:38 PM
moregrip's Avatar
what a rush!
80 something
Old Jun 11, 2005 | 08:46 PM
80 something
I must be having a stupid moment here. I'm thinking I'd be doing well over a hundred at 4800 in 3rd gear.
Old Jun 11, 2005 | 08:49 PM
moregrip's Avatar
what a rush!
lol, I'm admitting to nothing
would the speed vs shift value kick in? is that what your thinking?
Old Jun 11, 2005 | 09:10 PM
I guess the point I was trying to make was how often would you be at WOT and need another gear. I was thinking that I've never had occasion to be WOT and run out of rpm. I'm still thinking I would be at about 115 mph in 3rd at 4600 rpm. RPM calculator I just checked puts me at 151 mph @ 6000 rpm with my gears, and tire size.
Like I said I must me having a stupid moment.....
Anyway my shift rpm vs shift for 3-4 is at 8192. The shift speed vs shift for 3-4 shift is at 255 mph.
