22" to 16" swap
Old Apr 30, 2004 | 02:47 PM
Boosted 6.0's Avatar
Default 22" to 16" swap
After taking off my 305/40 22's and mounting some GMC 16" 265/70 rims and tires, how much time you think I can shave off the 1/4. How much improvement in the 60'? Worth the trouble? My goal is mid 13's with a 03Yukon Denali, Radix with about 10lbs boost (no boost gage), exhaust, intake, tune, and stock everything else.
Old Apr 30, 2004 | 03:58 PM
You should be their. Those 22's are heavy as hell and the 16's will give you better traction and remove alot of weight.
Old Apr 30, 2004 | 04:00 PM
Todd@AZPowerAndSound's Avatar
Depends on the weight total on each corner. Average 22" truck combo will weigh at least 85lbs. KNock that down to 60 and youll certainly shed the et.
Old Apr 30, 2004 | 05:16 PM
Todd, are you still in Scottsdale? I'm in Chandler, do you do anything but tires and wheels?
Old Apr 30, 2004 | 05:22 PM
Yes I am, and yes I do...whatcha need?
Old Apr 30, 2004 | 06:32 PM
F8L Z71's Avatar
I think I talk to you every once in awhile when my shop buys tires Todd. LOL
Anyway, yeah shedding that extra 25+lbs per corner will help out a ton. That's about 100lbs of mass but since it is rotational mass you can easily quadruple that and it is in effect like loosing 400+lbs of weight off the truck. I know the standard is 1lb rotating = 8lbs static but it's just hard to believe. lol
Old Apr 30, 2004 | 06:35 PM
Not hard to believe, I gained 8rwhp going from 17x11 315 nitto drags to 17x9 275 nittos on a back to back run.
However, my 60 ft was so much better..in this case the extra weight was ok
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
superchomper2003
Aug 26, 2015 09:39 AM
iregret
Jul 27, 2015 10:32 PM
