20w-50 oil to much?
Old Jul 27, 2006 | 01:14 AM
Dark Halo's Avatar
Default 20w-50 oil to much?
I swaped the pick up tube oring and my pressure is a little better but I was told to try using 20w-50 oil in order to help boost the pressure. What are your thoughts on this. I have been using 10w-30 and I plan on swaping to royal purple or castrol syntec on my next change.
Old Jul 27, 2006 | 01:18 AM
20w-50 is some THICK oil. woudl help boost pressure but adds a bit of resistance on all of your valvetrain components. i wouldnt go as extreme as that for now. can you get something a little more in between those. like 20w30 or 10w50 or something?
Old Jul 27, 2006 | 09:25 AM
Dark Halo's Avatar
I thought the same thing, I know 20w50 is used in Diesels but It told to me by a friend that is why I asked. My pressure is only low when it is hot. When it is cold it is good.
Old Jul 27, 2006 | 10:03 AM
how low is low? are you talking like 30psi? call a local mechanic and ask him what he thinks if you arent getting many responses here
Old Jul 27, 2006 | 10:30 AM
Coban's Avatar
Your engine will have an ever-so-slightly harder time moving with the thicker oil. I use 15w40 and have never had a problem. It was made for diesel engines and I get it for free where I work. This oil had extra detergents and my engine was CLEAN when I opened her up. Thicker oil is also better for high rpms I think.
Old Jul 27, 2006 | 10:45 AM
Dark Halo's Avatar
well by GM specs its good but at cold Idle I am now at 40-45 and hot idle is about 30. Cruise is about 45 or so hot. Before I swaped in the 6.0 my 4.8 cruised at 50-60 or so with the ported oil pump. I only noticed this drop when my oil sending unit went out and I replaced it with an oriley sending unit vs a delco unit. The only reason the thicker oil was suggested was because the oil is thicker when it is colder, so a frind of mine suggested an oil that is a little thicker when hot. I really just want was is best for my new motor. I replaced the oil pick up tube oring last night and my oil pressure bummped a little higher and the liffter tap is now gone. I had the wrong oring on when I put the motor together, my new one I got from the dealer was almost twicw as thick as the one that came in my lower end gasket set which I also got from orileys. It was a black oring to where the one the dealer gave me was thick and red in color.
Old Jul 27, 2006 | 10:50 AM
silver-mod-o's Avatar
Hunt&Fisherator
I run 10-40 in mine with no problems. if its a harsh winter I'll go back to 30W for a couple months
Old Jul 27, 2006 | 10:53 AM
Dark Halo's Avatar
well I am sure as you know here in the beaumont area we are not known for harsh winters. I think I wore shorts mosly this last winter.
Old Jul 27, 2006 | 11:00 AM
Hunt&Fisherator
yeah... I totally forgot you were down there LOL... it does get pretty damn cold up here in VA though. (at least its cold to me)... I say you'd be fine running some 40W... 50 may be a little much. you think the sending unit may just be off some?
Old Jul 27, 2006 | 11:45 AM
w41quad4's Avatar
One thing many people misunderstand about using a heavier oil is that while oil pressure might go up that in no way means that your oil volume is increased. I've seen a few engines turn to **** because someone ran a heavier oil that made good pressure but actually starved the engine in certain areas for oil, due to its in ability to flow as much heavy oil as thing oil.
