204/214 - 550/550 - 116 Lsa
Old May 22, 2006 | 01:05 PM
BradS's Avatar
Default 204/214 - 550/550 - 116 Lsa
in a 6.0 liter that I am not stalling. I want more power down low but not hurt my top end or mid range.
Anybody running a cam similar to this?
Old May 22, 2006 | 05:36 PM
Mr. Sandog's Avatar
You can go bigger than that in a 364. Comp's 212/218, .559/.563 (or even a little bigger) would be no problem.
Old May 22, 2006 | 06:52 PM
moregrip's Avatar
what a rush!
if your HD is like others then you have more stall in your converter than the 1500series bubbas. both my 1500HD and my 2500HD flashed to 2500rpm
Old May 22, 2006 | 10:24 PM
BradS's Avatar
It flashes to about 2200.
I really dont want it to be a pig off the line any worse than it is. I was talkin to the guy at Cam Motion and he told me if I go with much more duration it would hurt my bottom end.
I am looking for a cam that starts makin power about 1800 or 2000 and goes all the way across the board. Im not trying to make this a rqace truck just trying to get a lil more bottom end out of it.
Im thinking about going with something like maybe a 560/ 560 lift
Old May 23, 2006 | 01:49 PM
hog's Avatar
hog
hats becuase the 2500 and the 1500 HD both use the 2.48:1 1st gear 4l80e trans, while the 60e uses the 3.06:1 1st gear. The longer gear loads the TC more giving a higher stall speed.
peace]
Hog
Old May 23, 2006 | 01:56 PM
Z284thgen's Avatar
11 Second Club
holy cow is that even a cam
Old May 23, 2006 | 11:02 PM
ha ha thats what i was thinkin when i read it. fine for a 5.3 but for a 6.0...IMO you could add about 10* to each duration and still not have to stall that beast and be fine
Old May 23, 2006 | 11:15 PM
Richard@WCCH's Avatar
FormerVendor
I have a 210º/212º .559" on a 114º in a 6.0l ECSB. It has a stock idle and massive torque from the crack of the throttle. The truck tows a two horse trailer without any problems at any speed on any hill. A great choice with any stock or mild converter stall.
Good luck,
Richard
Old May 24, 2006 | 07:21 AM
BradS's Avatar
Yea the more I talk to peoplr the more I think I wanna go bigger. Im going to call and talk to them again.
Richard how is the bottom end on that cam from a dig? About what RPM does it come on?
I was also thinking about something like a 208 / 218 - 565/ 565 115 or 116 but the more I read the more I think Im going to go with something like a 210/218 - 560/ 560 115
Old May 24, 2006 | 07:34 AM
white1's Avatar
With the exhaust you have, I dont see the need for that much split on the duration. But Im no expert
