2014 6.0L L96 6L90E transplant issues
Old Jan 26, 2016 | 08:48 PM
trappercrk's Avatar
Registered User
Default 2014 6.0L L96 6L90E transplant issues
Got a pullout from a 2014 2500hd. 6.0L, 6L90e & elec tc. Installed into my 1998 K2500. New engine came with ecm & harness for eng / tranny / tc. Purchased correct 2014 underhood fuse panel, bcm, underdash fuse panel, instrument panel, harnesses, column controls, etc. Can start engine and shifts great. Problem is instrument panel gauges and PRND indicator don't work. Instrument panel does light-up and display errors (like no airbag & ABS - expected since don't exist). Also the reverse lights always 'on' when ket turned (with key turned, the bcm is sending signal to reverse light relay on underhood fuse panel). Thinking low spd GMLAN signal not getting to bcm or bcm not programmed? Been losing hair trying to solve issue for last 4 months. Guy on gm-trucks recommended this site.
BlueTexan24
Feb 6, 2016 11:27 AM
Jake75
Jan 26, 2016 02:56 AM
Prolong
Jan 25, 2016 12:13 PM
Slowchevy06
Jan 21, 2016 08:56 PM
carbed94z
Jan 21, 2016 05:18 PM
