2009 `500 w/4.8 monster cam, NA. Vacuum issues?
Old Oct 18, 2018 | 03:17 PM
SLOPONY's Avatar
Default 2009 `500 w/4.8 monster cam, NA. Vacuum issues?
I just picked up a 2009 Silverado 1500 with a 4.8 and a monster cam... 232/238 wth .625 lift. It was put together before I bought it.... So when coming off throttle it will disable the traction control, as well as stabilitrak. It also tosses a code C0299-5A Brake boost regulation pressure sensor plausibility failure. Is there any way that the low vacuum from the cam is causing that issue? if so would a vacuum can, or a vac pump help or fix it?
Old Oct 19, 2018 | 09:51 AM
Vortec350ss's Avatar
Its definitely possible. What is odd though is when letting off the throttle your vacuum should be greatest.
Old Oct 19, 2018 | 11:17 AM
SLOPONY's Avatar
I agree but if its highest level still is not enough, would that be causing the issue?
Old Oct 19, 2018 | 01:46 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Do you have any more info on the cam? Do you know what the LSA is??? Was it just slapped in straight up or advanced/retarded??? Any one degree it or verify it was cut properly?
Old Oct 19, 2018 | 03:34 PM
SLOPONY's Avatar
the work was done before I bought the truck so no idea.
rio68
Apr 28, 2017 04:37 PM
JeRM82
Feb 6, 2014 02:04 AM
