2008 Silverado 5.3 Drop Lifter and engine advice
Old Mar 9, 2014 | 01:49 PM
Isak81's Avatar
I dont recommend a ranger delete. It only disables the PCM from commanding it to turn on.
The parts that fail will stay and you will be fixing them again. I suggest doing a delete like in the link above, and talking to blackbear or nelson performance for a tune. They will do alot better than a tuner you buy that plugs in.
Old Mar 9, 2014 | 03:07 PM
69Camaro427's Avatar
Dealership is expensive unless you have a buddy that can get stuff at cost. Ls7 lifters are around $120-150 online.
Go ahead and put a baby size cam in it 212/218 range since you will be getting a tune anyways. I would up grade the push rods also if you decide to put a cam in it.
Old Mar 10, 2014 | 11:57 AM
Bartmon's Avatar
Originally Posted by 74silver911
You should double check but the lifters that were installed by the dealer in my Suburban back in early 2011 were part number 12639516. I think the new number is 12619820. Just FYI
you're right, the new part number is 12619820. thanks.
thanks for the advice and I'm leaning towards the delete kit.
I appreciate the advice, I just dont know if my wrenching skills are adequate enough to install a cam correctly.
Old Mar 10, 2014 | 03:59 PM
"I appreciate the advice, I just dont know if my wrenching skills are adequate enough to install a cam correctly."
Yeah I hear yea, it can be scarey if you have never done it or watched. It is so important to not nick the cam or bearings when installing or removal. Also very critical to get the cam lined up properly with the dots on the cam and crank gears. If the cam is off by a few degrees it will run like total crap with valves being open at tdc
Old Mar 13, 2014 | 11:34 AM
gagliano7's Avatar
GM LQ4 6.0L 2001-2007 460HP: High Performance Engines | ATK Custom Built Crate Engines
Old Mar 13, 2014 | 12:38 PM
Bartmon's Avatar
nice..and at a good price. thanks for sharing the link
Old Mar 13, 2014 | 02:48 PM
Bartmon's Avatar
I'm getting ready buy parts and was wondering if anyone thought it was a bad idea to save a couple of hundred bucks on buying the non afm active lifters (sealed power brand) from oreilly's or autozone for $9 as compared to the dealership for $35. it's weird because O'R wants $54 for the active lifter (sealed power brand) and the dealership wants $45 for the OEM...wth is that?
Old Mar 13, 2014 | 03:07 PM
See what they cost on www.SDparts.com
Old Mar 14, 2014 | 07:13 AM
gagliano7's Avatar
You can get ls7 lifters for around $120 bucks for all 16.
Old Mar 14, 2014 | 07:27 AM
Bartmon's Avatar
thats a good price but the afm lifters is where they gouge ya
