2005 Perfomance Goals
Old Dec 6, 2004 | 02:22 PM
  #21
Whistlin00's Avatar
14 Second Truck Club
My Goals are:
408 stroker motor
Longtubes
Posi
3000 yank
150 shot
Built 4L80E
X1 Cam
I want to shoot for 10's then save up for a turbo.
  #22
SLP 402
T-Rex Cam
Stage 2 heads
LS6 intake
3500-3800 stall
42# injectors
Bigger N2O shot
FLP level 4 tranny
Shooting for low 12's on motor and low 11's with juice.
Now i just need to figure out how to make it hook and stop spinning.
Old Dec 6, 2004 | 02:48 PM
  #23
foxspy's Avatar
My goal for 2005 is a 10.7x on a 150-200shot.
Start replacing little odds and ends that break in a 15 year old truck.
Old Dec 6, 2004 | 02:57 PM
  #24
L-EATER's Avatar
11 Second Truck Club
My goals are pretty big, probably bigger than my wallet right now, but here goes.....Build a 408 and put it in the '02. Build an intercooler setup and raise the boost, timing and Nitrous shot, and change the rear gears-shooting for easy low 10's
Then put the current setup (including the gears) in my worktruck (which already has the 5.3 and its own Whipple.)
I also plan on building a turbo Hayabusa somewhere in there. Guess I need to go get started, huh?
Old Dec 6, 2004 | 03:03 PM
  #25
Scream's Avatar
MOOBIES Moderator
You've got enough mph for 10s now...thought about ditching the leaf springs and running a 4 link?!
Old Dec 6, 2004 | 03:41 PM
  #26
2toneblown's Avatar
I think everyone knows mine. If not look at my sig. But mine should be done before the years up
Old Dec 6, 2004 | 04:45 PM
  #27
moregrip's Avatar
what a rush!
Project "Vroom Vroom" 2005
1. Install Magnuson Radix
2. Install TOG Headers
3. Install Jotto Desk/Laptop/HPTuners
4. Install Cam/Springs/Rockers
5. Install E-fans (PCM controlled)
6. Install DEEZ!
holla
Oh Yeah, some TransGo Goodies down low!
Old Dec 6, 2004 | 07:14 PM
  #28
04sierra's Avatar
Make my truck faster than my floor!!
-Install DyanTech LT's
-Install 160* Thermo
-Install UD pulley
-Flex-a-Lite's
-Lower it 4''/6"
-Get some wheels
And that will be about all I can afford next year.
Old Dec 6, 2004 | 07:22 PM
  #29
ACDenali's Avatar
My plans include installing my new cam (it should arrive any day now), LS1 edit, trans-go shift kit and a mild converter. Maybe late next year if I am lucky, get the Mcgaughy lowering spindles and Silvy SS rear lowering shackles....
  #30
L-EATER's Avatar
Scream-I turned a best of 119.8mph this season. Looking for 130+ next year. That was on a 60ft of 1.81 with no spinning. I was turning 1.6x 60 fts before the 4l80 so I am hoping the gear change will get that back for me. My truck has came pretty close to yanking the left front tire so until the I get to a point where the stock setup doesn't work then I aint touching the suspension.
