2004 5.3 into a 2000 with a 4.3...
Old Dec 17, 2008 | 01:23 PM
pewter00's Avatar
Default 2004 5.3 into a 2000 with a 4.3...
my motor is still sittin in the garage scheduled to go in the first week of january.. the guy who is doing the swap for me is telling me that i need to swap intake manifolds from the 04 to a 2000 intake manifold.. is this true?
he is also telling me that i need to get new tranny lines even though mine are fine.. is there a difference there also?
if i use the computer/harness on the 04, will i need to pick up an 03+ gauge cluster?
sorry for the stupid questions but i'm runnin out of time and i wanna know exactly what i do and dont need to get this thing in here and just forget about it for awhile this whole build has been a giant headache
Old Dec 17, 2008 | 02:52 PM
banker099's Avatar
use a 99-02 harness and the only thing you will need to change is the tb from drive-by-wire to drive-by-cable, trans lines are same, intake is same....you will need the engine and frame mounts for the 5.3 along with re doing the fuel lines too...i think that is all...pretty easy swap
Old Dec 17, 2008 | 05:15 PM
pewter00's Avatar
where can i find the 99-02 harness? also, if i went with an ls1 intake would i have the drive by cable throttle body? sorry for the stupid questions i dont know much
Old Dec 17, 2008 | 05:17 PM
GMCtrk's Avatar
dont get the ls1 intake, it makes less power than the truck intake.
The truck intake is the best intake you can use short of a FAST intake.
Old Dec 17, 2008 | 05:34 PM
pewter00's Avatar
so i just need to pick up a cable or a whole 99-02 intake?
Old Dec 17, 2008 | 05:37 PM
GMCtrk's Avatar
should be just the throttle body. I'm not sure if your current cable will work with the 5.3 throttle body.
Old Dec 17, 2008 | 10:54 PM
silveradokidd_4518's Avatar
just get the throttle body..
this was the easiest swap ever!!
97aztecgt
Aug 13, 2015 02:11 PM
darnie
Aug 10, 2015 10:25 AM
WarbirdLS1
Aug 8, 2015 10:53 PM
steves86ta
Jul 28, 2015 10:21 AM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
02, 04, 53
