2001 5.3 Rod bolt question
Old Feb 20, 2012 | 12:28 PM
TXSZ66AVLANCHE's Avatar
Make sure to get those ARP bolt dead nuts on correct...many did not install, torque, and check the stretch correctly and have spun rod bearings.
Old Feb 20, 2012 | 01:04 PM
88silvergt's Avatar
Originally Posted by Gadgetized
I think they mean that if you place an order you will get 2 bolts. At least where I checked that part # was only $15.
No, they show the pics of the stud part and the nuts. I looked on both summit/jegs and thats what it shows. Scroll down towards bottom and look at the pic with that part number.
JEGS High Performance
And here is summit.
ARP 134-6026 - ARP High Performance Series Connecting Rod Bolt Kits - Suggested Parts - SummitRacing.com
Old Feb 20, 2012 | 01:38 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
And here is summit.
Image is a representation of this part. Actual part may vary
Old Feb 20, 2012 | 01:41 PM
And I get a different part number, 134-6006 from the ARP catalog. I guess that's just a kit part number, vs 2 seperate bolts by themselves.
Old Feb 20, 2012 | 01:44 PM
CC05's Avatar
I ended up going with Katech rod bolts. I changed them in the truck by dropping the pan. It was not a hard job at all. If I had to do it over again, I am not sure if I would even do it. The biggest pain was the originals come with ferrules that need to be removed. After doing this, I seriously wonder if it put stress on the cap and could have distorted them. I think they make a puller for them, and I would get one if I were to replace bolts again.
And a lot of people have ended up distorting the rod cap for that exact reason. That's why I said to the OP, just avoid the rod bolts and drop the rpm's, which will most likely happen anyways because of where the power would come in with the turbo setup he's planning on. You can look at them as "cheap insurance", but they be more of a negative thing if they really aren't needed. I've got them and that's just my .02 cents.
Old Feb 20, 2012 | 01:45 PM
CC05's Avatar
Is this an updated part number? The number(s) I have are from when I purchased my bolts, which was quite a while back.
Old Feb 20, 2012 | 02:37 PM
No, I think this is a case where we're both right.
One part number is a complete kit, and one part number is 2 bolts. Here's a screenshot of the ARP catalog.
They are listed as bolt style "E", and the pic on the left margin shows a regular bolt. Hope this helps with some of the confusion.
Here's a link to the installation instructions. http://arpinstructions.com/instructions/134-6006.pdf
Old Feb 20, 2012 | 02:39 PM
CC05's Avatar
Awesome.
Old Feb 21, 2012 | 10:48 PM
88silvergt's Avatar
Yea, i'm hearing that the rods usually give before the rod bolts. If thats true then its really not worth it. Does anybody know for sure what year they upgraded the rods in the 5.3? Are the ferrels (small sleeves) that hard to get out?
Old Feb 21, 2012 | 11:45 PM
88silvergt's Avatar
I've found references for both 2005 and 2006. So just wanting to make sure. If I can find one cheap I will just start with that instead.
ferrellrooster
Mar 6, 2025 03:22 PM
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
