2000 Truck won't start :-(
Old Aug 25, 2008 | 07:44 PM
GMCtrk's Avatar
Did you unhook the battery?
Old Aug 25, 2008 | 07:47 PM
CashDudeHomie's Avatar
Yes I thought for sure that would fix it, but the same thing happens..
Old Aug 25, 2008 | 07:53 PM
GMCtrk's Avatar
When doing the security relearn you have to keep the doors shut the entire time, did you do this?
I don't know anything else, I'm a noobie when it comes to this stuff. Sorry.
Old Aug 25, 2008 | 08:01 PM
Oops! I'll try it with the doors shut lol. Thanks.
Old Aug 25, 2008 | 08:05 PM
Truckshop's Avatar
check the passlock wiring. if you just disconnected the remote start the wiring could be broken.
Old Aug 25, 2008 | 08:15 PM
GMCtrk's Avatar
In that case I don't think the truck would even start.
Old Aug 25, 2008 | 10:44 PM
1quick73's Avatar
as funny as this sounds check your relays switch your fuel pump relay with yhour horn relay annd see if it works, or just switch the fuel pump relay with one that fits, try it, i know casue my 00 sierra did the exact same thing, i checked my relays and did it never happendd again
Old Aug 25, 2008 | 11:48 PM
I can hear the pump running and it stops about a second or 2 after the truck kills itself. Ill mess with it some more tomorrow afternoon.
Old Aug 26, 2008 | 12:52 AM
nonnieselman's Avatar
you tried to command the fuel pump on with HPtuners?
Im just thinkin out loud...
Could be the Ignition? I know i helped my buddys dad replace the Ignition switch in his 01 cause it was doin the same thing.
My truck did this when i did the 80E swap but i had the wrong VIN in the PCM..
Old Aug 26, 2008 | 05:06 PM
Seems to be the passlock since I re-enabled it last weekend. It started right up this morning, but when I went to come home from work, same sh*t. I screwed with it for 15 minutes and got so pissed that I was pounding on the steering column as hard as I could and it started up. I pulled off the knee panel and clipped the yellow passlock wire while the truck was running.
I found this trick on an Impala forum with the same issues. Now it will run fine until I disconnect the battery, just the security light will stay on.
For a permanent fix and to turn off the security light, I need to take a voltmeter to the passlock wires and measure the resistance (if I can get the system to operate properly!) Then I will buy the appropriate resistor and wire it in and be done with it forever. I will keep you guys posted.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
