2000 Silverado lm7 budget build!!
Old Jul 2, 2018 | 05:44 PM
Grayson mcmillin's Avatar
Registered User
Default 2000 Silverado lm7 budget build!!
285 stock horsepower. Wanting to get mid 300’s fairly cheap. 1200 or less. Need a good cam that’s got a good low end toque with a decent top end power also. And any other suggestions to get me there. Trucks got 332xxx but body has just had a overall paint, it looks brand new and I want it to act brand new. Thanks for the help!!
Old Jul 2, 2018 | 06:17 PM
FFDP's Avatar
Anything in the 212/218 with a mild LSA of 114ish will do what you want on a stock stall converter. BTR, texas speed or comp cams all sell camshafts like that. Even slightly smaller will get a okay bump in power.
You'll need new valve springs, head gaskets, push rods and all that stuff. So half the budget is already gone. The rest will be spent on a tune and possibly slightly larger fuel injectors.
If you want more out of it than that your budget needs several hundred more dollars. A good set of headers and exhaust will help it make a little more power.
Remember that is 285 at the flywheel, so it's maybe making 220-240 at the rear tire. Add a camshaft and tune with maybe some exhaust work and it'll be up around 280-300hp to the tire and 340ish at the crank at a guess.
Old Jul 2, 2018 | 08:11 PM
Registered User
I’ve got a Efi live for the truck just never put on
CAGRacing
Jul 30, 2018 08:01 PM
rasputin713
Dec 15, 2017 01:08 PM
BryantTheGreat
19
Nov 12, 2017 10:41 AM
iregret
May 4, 2017 05:23 PM
NewSchool
Dec 7, 2010 08:21 PM
