2 Must Read Books!!!!!!!!!
Old Jun 30, 2006 | 05:09 PM
FastCrewCab4x4's Avatar
Default 2 Must Read Books!!!!!!!!!
To All, I went with my wife to the book store the past two weekends, While she was lookin for whatever it is that wifes read. I found two books you should get. 1) Tune and Modify Engine Management systems... 2) How to build High Performance LS1/LS6 V8s. Written by a guy that works for chevy, Knows every body and has some real good tips. Like what heads and cam to put on your LQ4 to end up with the same 405+ HP as the corvette. Has dyno sheets for all kinds af Chit From K&N to Radix To Nitros. some of you may have them, but for those who don't. before you spend money on any upgades spend the $40 for these two books. You'll learn allot and be heading in the right direction for what you want.... OK, Cool, Thought you should know.....
Old Jun 30, 2006 | 05:25 PM
nightrunner's Avatar
Mr. Obvious
thanks for the tip .. by the way does it cover turbos i one of them.. i would really like to be able to under stand all the comnponents of a turbo... and does it explain cams
Old Jun 30, 2006 | 05:45 PM
Neither go into specifics about cams or turbo Basics. The tuning book tells about AFR/ Boost pressure/timing. But I'm sure the book store has what you want.
Old Jun 30, 2006 | 11:09 PM
Derek @ EDO's Avatar
FormerVendor
this is my book store, it has all the info i need
Old Jul 1, 2006 | 12:14 AM
spitfire2332's Avatar
they have the LS1/LS6 book at autozone
Old Jul 1, 2006 | 06:40 AM
joshluther's Avatar
If the second book is written by Will Handzel be careful there is a lot of misinformation in it. Simple stuff like head bolt torquing.
Old Jul 1, 2006 | 12:58 PM
negativeswitches's Avatar
you can get those from amazon fairly cheap or ebay
Old Jul 1, 2006 | 10:07 PM
Tan327's Avatar
Thanks for making this thread, I picked up the LS1/LS6 book at Auto Zone today. I'm glad I bought it, but it didn't tell me a whole lot that I didn't already know from researching on this site. I thought the book had a GREAT section explaining different types of intake manifolds and such. I haven't read the tuning stuff at the end yet, and I'm sure I can learn a ton in that area.
Old Jul 2, 2006 | 01:59 PM
closet red neck's Avatar
There's another one too.....the Chris Enderles book. This might be the same book that your refering to also. If not, this one is a good one to. I've had these two books for about year now...maybe longer.
James
nabozny21
Oct 17, 2015 07:47 PM
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Lthompson
Oct 2, 2015 12:45 AM
Closer_2001
Sep 24, 2015 09:15 PM
