1999 silverado 4.8 to 6.0 swap help, truth needed
Old Jun 7, 2012 | 07:54 PM
  #21
mopower440's Avatar
i keep hearing about a bad batch of heads called castechs? What year engines were they on so i can avoid getting an engine of that year..?
Old Jun 8, 2012 | 01:16 AM
  #22
green02's Avatar
706 casting 99 up gen 3 heads. Not all of the 706 heads were castech though. If you do a search someone posted about what the casting mark looks like and where it is to id a castech vs non. Hope this helps
Old Jun 8, 2012 | 05:23 PM
  #23
mopower440's Avatar
99-up, all the way to 2006? man, that sucks because was looking at engines on e-bay because there are non around here, so i would be taking a big chance not being able to look at the heads, crap!
Old Jun 8, 2012 | 07:27 PM
  #24
TXSZ66AVLANCHE's Avatar
Originally Posted by 1Bear
Even with all the different displacement engines having the same casting number crankshaft, this doesn’t mean the crank can just be pulled from one engine and installed in another, as they were individually balanced and the car engines even had gun drilled crank, so re-balancing would be prudent.
The 5.4 in my Suburban has a LS1 gun drilled crank, over 10k miles so far and no problems or vibration.
Old Jun 8, 2012 | 09:11 PM
  #25
1FastBrick's Avatar
Custm2500's Rude Friend
All you need to do is ask them to look at the 3 digits cast on the outside. 706 and 862 are the ones that would apply to 4.8/5.3L some of the later engines got a 799 casting which is identical to the 243 heads.
Old Jun 8, 2012 | 09:29 PM
  #26
1Bear's Avatar
I said prudent, not that it wouldn’t work. Anytime rotating assembly components are swapped from one engine to another, balance should be checked. Just because in one case it worked out doesn’t mean I would go around recommending it. However in the case with the gun drilled vs solid cranks the metal being removed from the centerline, it doesn't have as great of an effect as it would if the metal was removed from one of the rod throws or counter-weights.
Old Jun 8, 2012 | 09:40 PM
  #27
1FastBrick's Avatar
Well Said!!!
Old Jun 8, 2012 | 10:01 PM
  #28
My comment was not argumentative, simply stating that for a mild engine in a daily driver the crank difference is not a big deal.
Old Jun 8, 2012 | 10:08 PM
  #29
1Bear's Avatar
I understand, but so many people do misunderstand others statements and would turn it into something it’s not meant to be and we all know how assumptions go. I read it on such and such and next thing you know it’s the gospel.
Old Jun 8, 2012 | 10:33 PM
  #30
1FastBrick's Avatar
As mentioned "in general" it is a good idea to have it checked for balance for your application. It may work just fine, but the weight of say a 5.3 piston and rod is different from say that of a 6.0L.
No harm no foul
