1999 silverado 4.8 to 6.0 swap help, truth needed
Old Jun 5, 2012 | 10:07 PM
Wide Open's Avatar
Mileage stayed the same (17-19 mpg) with 4x4. Swapped in a 6.2 later with a 6L80E/AWD and it still stayed the same. Hard to drive a 400+hp RCSB like a sane person though
Old Jun 5, 2012 | 10:08 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by 1Bear
Correct, the 1999 & 2000 model 4.8L engines mated to a manual trans were the only long style crank Gen III engines outside of the same year model 6.0L's.
Good Info!!!
I have heard that but have never seen one my self.
I just wanted to make sure people knew that it was NEVER mated to the 4L60E
Old Jun 5, 2012 | 10:12 PM
1Bear's Avatar
The wide flange 4.8L crankshaft was casting number 12553312, while the narrow flange crank had a casting number of 12553482. The wide flange 6.0L had a casting number of 12552215, whereas all the other Gen III engines had a narrow flange crank with a casting number of 12552216. Even with all the different displacement engines having the same casting number crankshaft, this doesn’t mean the crank can just be pulled from one engine and installed in another, as they were individually balanced and the car engines even had gun drilled crank, so re-balancing would be prudent.
Old Jun 6, 2012 | 06:32 PM
mopower440's Avatar
getting more and more excited about this swap. Only sucky thing is that i could get a 5.3 for half the price of a 6.0 though..
Old Jun 6, 2012 | 06:45 PM
Wide Open's Avatar
Sounds like what you need is a 5.3 with a turbo
Old Jun 6, 2012 | 07:09 PM
RibeiroBJJ's Avatar
Praise The Lowered
Why even go through the trouble of a 5.3 swap? The 4.8T seems to be a proven setup..When I buy my GMT900 rcsb I will turbo it and avoid ALL the other headaches..
Old Jun 6, 2012 | 07:13 PM
mopower440's Avatar
not swapping till the 4.8 is worn out, just planning ahead and figured since its a direct swap, might as well go a little bigger, no turbos or anything..
Old Jun 6, 2012 | 07:17 PM
Wide Open's Avatar
Just said it to be funny. 4.8T does seem to be a proven setup. I probably wouldn't do the swap either if I was going with a turbo.
Old Jun 6, 2012 | 07:25 PM
Wide Open's Avatar
The 6.0's make a bunch more torque stock for stock.
Old Jun 6, 2012 | 09:58 PM
Scrapin'4.8's Avatar
5.3's around me are gettin cheaper and cheaper. i've found 10 within an hr drive of me for $450 or less, complete engines. 6.0's are $1200 or more. If it were me and i had a 4.8 i would keep it, buy a spare 5.3, maybe 2, and then full bolt on's and some sort of FI or sweet nitrous setup. I think i would only get a 6.0 if i could find one on the cheap.
