1999 5.3 valve seal part #'s
Old Mar 24, 2004 | 07:51 PM
99Silver6.0's Avatar
Default 1999 5.3 valve seal part #'s
Anybody have a definite part number on the intake and exhaust valve seals for a 1999 5.3? Getting my stuff together for my cam swap and want to get some new valve seals. Also....... I want to make sure I got the right LS6 springs. I ordered 16 of part #12565313. Is that correct for the 2002 .550" Springs? Yellow right? Also, are the below part numbers I ordered correct for what I need?
12557840 Water Pump Gaskets (2)
12558013 Timing Cover Gasket
12561244 Front Crank Seal
12557840 Pulley Bolt
Old Mar 24, 2004 | 10:42 PM
Anybody have a tuned Edit file of a 5.3 with a 212/218 .522/.529 114 cam?? Im trying to see what Im gonna have to do to get my truck to run after the cam install.
Old Mar 24, 2004 | 11:17 PM
dont forget valve cover gaskets
Old Mar 25, 2004 | 12:50 AM
That I did forget about. I think I have the part # for them. Anybody wanna share a cam flash?
Old Mar 25, 2004 | 05:35 AM
02Reaper's Avatar
I just had one installed yesterday. All that I had to do was raise the idle in edit by 150 rpm's. I just added it to all of the rpm's listed in that one tab. It runs good now, you cant even tell that its in there by the sound. I set it to shift from 1-2 and 2-3 at 6200 rpm's and it pulls all of the way to the shift. I didnt loose any on the lowend either. Actually it starts around 1800 rpm whereas the stock one started pulling at around 2500 rpm's.
Old Mar 25, 2004 | 07:19 AM
Sweet, whats your cam specs?
Old Mar 25, 2004 | 04:27 PM
Hit Man X's Avatar
I'd probably do a timing chain as safe measure while you're there and an OE oil pump (though Melling does have a nice aftermarket one out now!)...
Old Mar 25, 2004 | 04:36 PM
02Reaper's Avatar
02,
Same thing your installing. comp cam 212/218 522/529 114 lsa. I will send you the edit file if you need it. I already have all of the quirks programmed out.
Old Mar 25, 2004 | 05:35 PM
Oh man. That would be much, much, much appreciated! That would help me out remendously!
My email jtskier11@kc.rr.com
Old Mar 25, 2004 | 08:43 PM
jlwz71's Avatar
Would you send me the file also to jlwz71@ntelos.net? I would like to see what you have done for the idle. Thanks.
