1998 Z71 w/ 5.7 vortec running rough
Old May 15, 2008 | 03:06 PM
Dennish's Avatar
Registered User
Default 1998 Z71 w/ 5.7 vortec running rough
This is no high performance engine or anything,just trying to get it to run.Posted on other forums and no response. motor started to run rough. Would almost die when coming to a stop.Got worse , now it starts runs real rough and when you put it in gear it dies. Fuel pressure at 60 .changed fuel filter,plugs,and distributor cap. I took the injection system out and noticed 2 cylider ports were clean compared to the others all carboned up.Any response would help. Thanks
Old May 15, 2008 | 10:35 PM
454SuperSport's Avatar
is it throwing any codes? loosing coolant by any chance? could be the EGR valve stuck open, or one of several sensors.
Old May 15, 2008 | 10:53 PM
2005 Silverado's Avatar
SPAM HUNTER
EGR will stick closed very rarely open...does that year have a IAC...or something simular?
Dustin
Old May 16, 2008 | 08:49 AM
Dennish's Avatar
Registered User
Battery went dead before i could have someone run the code,so no codes would show. He looked at it last nite and said that 4 and 7 injector tubes were leaking fuel. Thats why those two and around that area were clean compared to the others.So now i guess i going to change those two injectors.Put back together and then see if any codes pop up. Thanks again for the response, seems that other forums either dont know ,or they dont respond very often. Thanks again. If anything else i might need to check ,please let me know.
chadjcompton
17
Jun 21, 2022 08:47 PM
stealthperf
34
Feb 14, 2016 11:35 AM
ROB 1 TON
Jul 13, 2015 04:43 PM
4B11T
Jul 13, 2015 03:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
