1998 spark plugs
Old Jan 27, 2010 | 08:06 PM
Default 1998 spark plugs
hi guys i am looking at doing tune up plugs and wires and cap and rotor my question is what are some good options for spark plugs? let me tell you about the truck i have a 1998 K2500 5.7L it is not a dayley driver i typically only use the truck for pulling trailers or when i go up north with that is there a better plug fot towing than the stock acdelco i beleve i have NGK TR55 in the truck know anny sugestions on what plugs i should use would be great thanks
Old Jan 28, 2010 | 12:02 AM
ChevyMan90's Avatar
I run the AC Delco "Professional Platinum" Plugs in mine. I changed them out when I did my headers at around 96000 miles. They're supposed give you 100,000 miles of use before needing replacement. They've been doing good so far.
Old Jan 28, 2010 | 01:36 PM
anny other sugestions?
Old Jan 28, 2010 | 02:00 PM
00ChevyScott's Avatar
Wearin' da big hat
I wouldn't recommend leaving them in that long chevyman, the platinum tips like to fall off and get stuck to the cylinder heads
Old Jan 28, 2010 | 04:31 PM
i dont leve plugs in verry long about every 2 years i replace them i am just looking for good sugestions on typs of plugs i should use
Old Jan 28, 2010 | 08:26 PM
budhayes3's Avatar
PT's Slowest Truck
Your best bet is the stock ACDelco's or comparable NGK. If you're looking for an extended interval between spark plug changes, go for either platinum or iridium. Supposedly, iridium plugs are supposed to be better at not leaving as much carbon behind, but I don't know if that's fact or just marketing.
Old Jan 28, 2010 | 08:28 PM
ChevyMan90's Avatar
I replaced the my original AcDelco Plugs with the platinum ones. I only have around 3000 miles on them so far. I've read that the platinum ones don't last as long but we'll see.
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
