180 stat running 200
Old Jul 31, 2010 | 10:46 PM
05gmcsierra's Avatar
it sounds about rt.. my cuzen got a 180 and he said it stayed rt under 210 and me on the 160 im always at 180
Old Aug 1, 2010 | 01:01 AM
double047's Avatar
14 Second Truck Club
Originally Posted by terravast4
My 160 runs about 175-180. In bumper to bumper traffic never goes above 185 even in 100+ weather.....but the fans are tuned for the thermostat.
This is key, when you run the lower tstat tune the fans to the stat.
Old Aug 1, 2010 | 08:45 AM
Gh0st's Avatar
Jedi Master
Originally Posted by mhotrodscooter
What's the reason behind changing it? Was to help it run cooler r was the temperature running a little higher then normal?
My 160 runs about 180 depending on weather & if a/c is on! I've seen it go up to 210 on a hot day stuck in traicff
Letting the coolant flow earlier isn't enough to keep the temps low. The fans have a double-duty job of pulling heat off the radiator and pushing heat off engine itself.
Old Aug 2, 2010 | 11:38 AM
nonnieselman's Avatar
Originally Posted by 06Sierra2
if the trans lines run through the radiator before the cooler, then will a 160* stat vs the stock one in fact keep your trans fluid slightly cooler?
In theory it should.. cant say ive payed that much attn to that tho.
Oobray
Jun 13, 2022 03:38 AM
X_Racing1
21
Mar 30, 2016 02:37 PM
stealthperf
34
Feb 14, 2016 11:35 AM
ZONES89RS
21
Sep 24, 2015 05:58 PM
BigEd_72455
Aug 8, 2015 07:37 PM
