175 (crank) shot on stock fuel pump and injectors?
Originally Posted by 2000_Silverado_SS
I was thinking it was 150 also. You should be fine. I sprayed 62/35 for three years with no problems. When I went above 175 I started hearing stuff literally coming apart in the bottom end.
Hold on tight when you hit it, it's a heck of a jolt, better have tires too or you'll just go up in smoke!
What could your truck run the 1/4 with the 125 shot?
crazycutter: Did you run that 12.6 with the 170 rwhp shot or the 220 shot ?
Originally Posted by tooquick2beslo
I could have probably ran a 13.2-12.8
and broke a piston.Can't wait to spray the hell out of this new motor!
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
My theory is, isnt there guys on here running a 150 shot from NX that is rated at the tires on stock fuel pump and injectors ?
If that is the case then a 175 (crank) shot would be equilivant to a 125 rwhp shot. Correct ?
That was with a 170 dual stage shot, nos dry 70 shot off the line & tnt wet 100 shot about the 40ft mark.
How big of a shot are you running ?
You think 2 bottles sprayed through it will be ok with some octane booster?
I plan on spraying a bottle to do some logs and a bottle at the track.
I was running 13.1 with the 62/35 jets. Ran 12.6 once with about a 180 shot. Then went to a 200 shot
and broke a piston.
Have you logged it when spraying the 62/35 jets ?
If so, what was the a/f and injector duty cycle?
Chingon: what kind of kit do you have? one rated at the tires ?
Greysilver: Yea I understand what you are saying about the fuel pump.
I think I may get away with it once. I am just trying to break into a mid 12.
That 175 shot you have is rated at the crank correct ?
Is your truck extended cab?
yep NX rates at the rear wheels so you go ahead and spray that 175 whp shot on that bottom end and let me know how it works out i would not do more than a 125 on stock injectors and fuel pump but this is my daily driver if this is dead then so am i some people may disagree with me and that is ok but i would definately upgrade fuel pump and injectors before i started going to far with the ole engine cleaner
