160 t-stat or 180 t-stat
Old Mar 7, 2006 | 11:27 AM
04blackvho's Avatar
Default 160 t-stat or 180 t-stat
well going to get nelson tune should i get a 160 or 180 what do you guys use
Old Mar 7, 2006 | 11:31 AM
Whippled 496's Avatar
I use a 160* with the whipple
Old Mar 7, 2006 | 12:47 PM
white06's Avatar
I found out the stock truck stat is 186 or 187. I couldn't find an actual 180.
Old Mar 7, 2006 | 12:54 PM
FlaBouy's Avatar
Use a 160. My Blown AV runs around 180 with the 160 installed....
Old Mar 7, 2006 | 04:54 PM
03lowriderss's Avatar
Slp 160*
Old Mar 7, 2006 | 04:57 PM
treyZ28's Avatar
180 unless you're boosted
no reason to go 160 at all. Less power, worse gas milage.
Old Mar 7, 2006 | 05:50 PM
w41quad4's Avatar
Less power & worse gas mileage, I really hope you have something to back that up, because i've experienced neither of those two problems running a 160* for the past few years. The truck once warmed up will still typically be in the 180 range.
Old Mar 7, 2006 | 06:03 PM
Post
I'm kinda going to have to side with Trey on this one.
Not about the less power, but the worse MPG I agree on.
Not too sure how the 4.8 & 5.3L react to the 160* stat, but my VHO's LQ9 6.0L sure lost 1 mpg on average after dumping the factory stat for the SLP 160* stat.
It just takes way too long for the engine to warm up. During warm up it uses a tad more gas than when the engine is at close to normal operating temps.
Once it completely warms up, it does fine.
My 1/4mi times was 1/10th better after the 160* stat install. Could have just been a better run, but I didn't lose any 1/4mi time.
If I did it over, I would find out were to get a 170* stat.
A member here posted about finding one from somewhere, and it worked great for him.
Guess you would just need to do a little bit of research on it.
Jim
Old Mar 7, 2006 | 10:48 PM
getchusum99's Avatar
i have the 160' hypertech stat in my truck and did notice a slight drop in milage as well.
Old Mar 7, 2006 | 11:00 PM
1slowsilverado's Avatar
If I lost any gas milage it was slight. I went from stock 187 (ran 194) to a 160 (runs 172 now) I am running a tad more timing now and feels stronger all around. I'll keep an eye on my milage though...
