15psi 408 gtech, this thing is geting fast
Old 01-18-2005, 01:10 AM
  #41
F8L Z71's Avatar
Interesting. Do you have a link to the add-on you're talking about Jim? i doubt I'll be needing it but I know 2wd guys like Chris could possibly benifit from it.
Old 01-18-2005, 06:29 AM
  #42
single digit dreamer
parish8's Avatar
http://www.sr20tuning.com/ebc.html
i have the sbc id boost controler. for some reason you need that other part, the power meter id for the speed based map funcitions to work.
Old 01-18-2005, 08:44 AM
  #43
zippy's Avatar
that boost controler should help alot. they are big in the syclone world for quick awd times. i think the front diff should hold up fine. the lingenfelter s10 with the 427 and twin turbo if i recall last time i seen it had stock front and rear diffs which were only 7 5/8 rear and 7 1/4 front. if those diffs can hold up under awd burnouts with drag radials, your half ton diffs should be fine... except that gov-lock...
Old 01-18-2005, 09:53 AM
  #44
F8L Z71's Avatar
damn, seems you have to keep the wastegate lines as short as possible with this unit. My lines are ran from the rear axle to the front intake manifold. SOmehow I assume that's too long LOL.
TrendSetter
11-26-2018 07:18 AM
Go5.3tt06
25
09-04-2016 10:25 AM
murderedSS
27
10-12-2015 11:13 AM
RONIN LSX
09-05-2015 10:55 AM
Quick Reply: 15psi 408 gtech, this thing is geting fast
