145 AMP ALTERNATOR Will it work?
Old Mar 16, 2005 | 10:42 AM
blue 01's Avatar
Got mine Saturday (well, past midnight, so technically Sunday)....probably the same guy...$100 shipped. Does this look familiar?:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7961103822
Here's the info on the belt from GMPartsDirect.com:
Part: 12576451
Unit Price: $27.23
SHIPPING: $7.95
TAX: $0.00
TOTAL WITH TAXES: $35.18
Unfortunately, I'm gonna be away this weekend, so I won't get a chance to work on the truck if the alternator arrives...leaving Thursday night. (unless of course the alternator shows up tomorrow...then that's a whole new story )
Yep thats who I got mine from.
Old Mar 22, 2005 | 08:28 PM
budhayes3's Avatar
PT's Slowest Truck
Guess what...It works!!! (did it tonight after work) Piece of cake, bolts right in...hardest part was running the serpentine belt with a fresh tattoo on my right wrist and forearm...it's still pretty sensitive. You just need the longer belt GM part#12576451 Wahoo!
Old Mar 22, 2005 | 08:35 PM
creederado's Avatar
good,
Old Mar 22, 2005 | 08:37 PM
what's the advantage to running this alt?
Old Mar 22, 2005 | 08:48 PM
budhayes3's Avatar
PT's Slowest Truck
Well, for me, it allowed me to use an 02 PCM in my 99 without having a flashing battery light. (the 02 PCM's are better than the 99's, and aren't as prone to false knock). The 02 and up system has an extra wire that runs from the PCM to the alternator, and just running that wire didn't turn off the flashing battery light that occurred upon installation of the 02 PCM. Turns out that the 02 PCM has some sort of duty cycle circuit in it and the 02 and up alternators are different...or maybe the higher amp alternators are different. Either way, this alternator was the last link in curing my flashing battery light.
The main advantage for most is that it is a higher amp rated alternator, which will allow you to add more electrical accessories without causing a drain that your electrical system can't handle (sound system, electric fans, etc.)
Old Mar 22, 2005 | 09:24 PM
While doing this upgrade, upgrade the wire from the Alt to the terminal with at least a 4ga wire. Also add another ground of equal size from the (-) terminal to a good ground.
That alone will make a big difference in the output.
HectorM52
Aug 18, 2015 12:40 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
