14 Silverado 5.3 oil change
Old 10-24-2018, 04:45 PM
jimmys5600's Avatar
Default 14 Silverado 5.3 oil change
Hello, My 14 Silverado only has 11k on it. The oil changes have been performed at the dealership.
I wish to change it myself and wanted to be sure as to how many quarts to get and what weight?
The manual calls for 0w40. Unsure as to what to use.
Thank You
Old 10-24-2018, 06:08 PM
FFDP's Avatar
Are you sure it said 0W40?
The oil cap says 0W20 on those trucks and you need 8 quarts of oil plus a filter.
Old 10-25-2018, 11:18 AM
jimmys5600's Avatar
My bad,old eyes I guess. lol Yes 0w40
Old 10-25-2018, 05:03 PM
FFDP's Avatar
Bad fingers too lol.
You typed 0W40 again.
Old 10-25-2018, 08:42 PM
Ecrod103's Avatar
If you own a 2011 or newer GM vehicle, you must use a motor oil that meets GM's dexos specifications to maintain that vehicle's warranty. There are some exceptions. The dexos specification applies to most, but not all, GM vehicles model year 2011 or later. DEXOS should be on the bottle
Old 10-25-2018, 08:44 PM
FFDP's Avatar
Everything synthetic meets or exceeds dexos ratings now and 0W20 only comes in synthetic.
Old 10-26-2018, 08:06 AM
Mark Johnson's Avatar
Out of warranty can I get away without the Dexos- is it really necessary...………..
Old 10-26-2018, 08:13 AM
03sierraslt's Avatar
0-20 is necessary and I think all 0-20 is dexos approved as only 0-20 is synthetic.
Mark Johnson (10-26-2018)
Old 10-27-2018, 10:59 AM
1994Vmax's Avatar
0w20 is under no circumstances necessary... Gm uses it in the trucks for a tiny nearly immeasurable bump in fuel economy. You can run 5w30, 0w30, 10w30 or whatever.. it will do just fine
Old 10-27-2018, 02:16 PM
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Wouldn't agree with the above. Newer motors are tighter clearance and I def would
run the Factory recommendation. Oil is cheap, $40 for 6 qts of Mobile 1 at your local
Sams Club.
Quick Reply: 14 Silverado 5.3 oil change
