112 vs 114 centerline
Old Feb 8, 2006 | 08:02 PM
912jonathon's Avatar
Default 112 vs 114 centerline
im fixin to buy a cam for my truck and was talking to a guy from thunder racing and he recommended a 114 centerline but i want a choppy idle. he said a 112 might have problems when coming to stops keeping to truck running. what if yalls experience with this??
Old Feb 8, 2006 | 08:08 PM
bluecajun5.3's Avatar
11 Second Truck Club
he's right about the 112 stalling at stops. the only way you can fix that is to have the tune perfectly tweaked out. i have a mail order tune and sometimes i have suges at stops.
Old Feb 8, 2006 | 08:20 PM
AintNoHo's Avatar
If it stumbles a little on idle you can raise the idle 100 rpms. I have no problem.
Old Feb 8, 2006 | 08:23 PM
ok, how hard does the 112 chop over the 114??
Old Feb 8, 2006 | 08:24 PM
YenkoST's Avatar
I don't have a problem with 112 lsa with a idle set at 600rpms. The 112 will be choppy compared to teh 114.
Old Feb 8, 2006 | 08:27 PM
YenkoST's Avatar
depends really on the duration. more duration on a 112...the more you will definately notice it.
Old Feb 8, 2006 | 09:26 PM
Sport Side's Avatar
Just a FYI...
The 'centerline' is not the lobe seperation angle, which you seem to be referring to. There is a exhaust, and intake centerline. These are at peak lift of the exhaust lobe, and peak lift of the intake lobe.
The lobe seperation angle (LSA) is the seperation between the lobes. Tighten this and you increase overlap. Spread it and overlap decreases.
Also, a camshaft with a 114 degree spread and with 4* of advance puts the ICL @ 110 degrees and the ECL at 118*. So, your exhaust events have moved to a later position relative to the pistons position and the intake events are taking place earlier.
Old Feb 9, 2006 | 05:10 AM
samdogmx's Avatar
8 Second Club
depends on the duration, I have a 206/210 with a 112 lsa & i love it, its only a little choppy at idle but i have no problems & i dont even have a tune for it yet.
natejk
Nov 15, 2016 08:05 AM
TAPyvehc93
Dec 27, 2015 12:14 PM
Jake75
Oct 2, 2015 02:28 PM
bisqikss
Sep 27, 2015 09:40 PM
bluebommer07
Sep 20, 2015 08:42 PM
