11 lb pulley on! Last minute ??
Old Sep 3, 2003 | 09:33 PM
Black Blown 02's Avatar
Default 11 lb pulley on! Last minute ??
The 11lb pulley is on. I tuned the truck to 11.7-1 across the board A/F, for the 8 lb'er. When the maf suddenly sees that much more airflow at any given rpm, it should stay close to 11.7-1, right? Just want to make sure I don't go lean for some reason.
I'm going to go to 4500 rpm logging for KR first, then go to 4500 logging A/F. Then maybe 4800, then 5100, 5400, and so on. Hopefully everything goes well.
Old Sep 4, 2003 | 12:14 AM
Default Re: 11 lb pulley on! Last minute ??
Ok went out and did some logging. A/F stayed at about 11.5-1 through the run. No KR, running it on my safe tune with shifts at 5200.
Seeing 8psi at 5200, used to see about 5.5psi at 5200.
MAF readings went from 36.7 lb/min at 5200 to 42.43lb/min at 5200! I used to only get 40lb/min at 5800 rpm.
It feels like it is quite a bit faster than it was before even though I'm short shifting it.
I'm taking it up to 5600 for the shifts next.
Old Sep 4, 2003 | 08:06 AM
Ryan@RPM-Motorsports's Avatar
Do you have bigger injectors? I was leaning out at 5200 rpm w 11lbs. put larger injecters in and solve the problem. (w/tuning).I get 11lbs at 4500 rpms
Old Sep 4, 2003 | 06:30 PM
Yeah, got 43 lb'ers.
Old Sep 4, 2003 | 07:03 PM
parish8's Avatar
single digit dreamer
sweet, watching with intrest.....
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
