102mm dbw
Old Feb 20, 2019 | 04:45 PM
Go5.3tt06's Avatar
Default 102mm dbw
Wonder this will work on my 2006 silverado high ram intake for that, what about harness adapter I cant find it. If you can help me out? I dont want use my stock one truck throttle. I have lsx427 in work on turbo need a good throttle.
Old Feb 20, 2019 | 04:51 PM
03sierraslt's Avatar
Good luck finding a 102 that works on our computers with decent boost. I just went DBC 105 on my blower setup, and will stick to a 90 on my turbo.
Old Feb 20, 2019 | 05:23 PM
TXsilverado's Avatar
I haven't had a problem with my NW 102mm at 17lbs. I'm using dominator EFI though. I think the people running aftermarket ECUs have better luck with them over people using the stock ECU.
Old Feb 20, 2019 | 06:47 PM
Go5.3tt06's Avatar
Just need to know if this eBay throttle 102mm ok? But i need find harness adapter for throttle. I’m goingnrun ms3 pro guy is work on it for me
Old Feb 21, 2019 | 09:59 AM
Go5.3tt06's Avatar
eBay
it seem expensive normal for just adapter harness?
That mean I need get Nick William 102mm with boost version? Do you know anywhere price cheaper compare other store sell those? I would appericate it.
Old Feb 21, 2019 | 10:18 AM
I had a “boosted 102” from NW and it still failed. FYI
Old Feb 21, 2019 | 10:22 AM
the problem seems to be more related to P59 ECM’s. They are more sensitive.
Old Feb 21, 2019 | 02:19 PM
Go5.3tt06's Avatar
then what other you use throttle since i have holley ram intake on it
Old Feb 21, 2019 | 04:40 PM
On my turbo setup I am just running a LS2 90.
90mm will support a lot of power on a blow through setup. I got tired of the damn issues with 102’s, the DBC 105 worked good but I like the tunability of DBW.
i have a Hi Ram on mine also.
Old Feb 21, 2019 | 06:49 PM
Go5.3tt06's Avatar
so should i go ls2 90? What about harness plug
how about swap drive by cable and will tune delete code like abs, brake light on if swap Dow to cable??
