10-40 oil and other questions...
Old Mar 25, 2010 | 02:59 PM
ChevyTruck's Avatar
something else
Question 10-40 oil and other questions...
I was talking to a guy at work and he was saying that he uses 10-40 in all of his engines, from lawn mower to his Blazer and he swears by it. I have always used 5-30, would it hurt to use 10-40?
I think I am starting to get a leak some where, noticed it today when I parked, I got a sent of something burning and looked under the truck and there was/is something that is leaking from the back of the block where the trans bolts to the block. Oil pressure is staying good and the temperature is normal. The leak looks dirty and thin, I can not get a good sent off of it. I need to pressure was the under side and see where its coming from. But I would like some ideas to where it is coming from.
Old Mar 25, 2010 | 03:01 PM
Dewey's Avatar
the leak is the rear main seal, most likely. how many miles do you have on your truck?
i run 10-30 in my truck, but have always been taught to increase the viscosity of oil in older, high mileage vehicles.
Old Mar 25, 2010 | 03:07 PM
ChevyTruck's Avatar
something else
I have 87,7xx miles on it. and I know that most of them are HARD miles, it has been used and abused.
Old Mar 25, 2010 | 03:46 PM
Dewey's Avatar
i figured it would be somewhere around 100k. most likely it is your main seal. you can go to advance auto or whatever your favorite auto parts store is and pick up some rear main seal repair. the stuff that i used is made by Bar's Leaks. you put it in about ~ 500 miles before you change your oil and it expands and repairs your engine seals.
Old Mar 25, 2010 | 03:59 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
check around your valve covers
I run 5-30 or even 0-30 in my truck. I think there are a lot of misconceptions about lubricants. There was a really good article posted not too long ago about modern motor oil.
Old Mar 25, 2010 | 04:03 PM
TIM Z's Avatar
11 sec. Truck Mod
I used to be " old school" and run 10w30 or w40 in my vehicles.
but the the new engines are built with tolerences that are tighter so 5w30 is reccomended,
And the thinner oil frees up power ( minute but still) and gets to where it needs to be sooner on start up.
Either way i think your fine but i like 5w30 in mine.
Old Mar 25, 2010 | 08:29 PM
ChevyTruck's Avatar
something else
Thanks guys for the input. Did a oil change and went to 10-30. I will clean the under side and see where it's coming from and also just tighten the valve covers.
Old Mar 25, 2010 | 10:26 PM
tarinitup's Avatar
9 Second Truck Club
I use 20w 50 and it really reduced blow by in my turbo app. My pistons were gapped loose for nitrous and this was a good fix. Only thing I noticed was higher pressure when cold but once it's warmed up it is normal.
Old Mar 25, 2010 | 10:32 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
10-30 is only thicker when not at normal operating temps. On cold engine starts, it will take longer to pump thru your engine, thus increasing wear(over time). Once at normal operating temp, the viscosity is the same as 5-30. That's the whole point of multi-viscosity oil. You should consider switching back to 5-30.
On a side note, in the 90's GM determined that using a 40 wt oil caused the rings to stick in the ring-lands(over time). Something about the way it burned off the cylinder walls, and the design of the pistons. Of course, this was in the days of the SBC. I'm not sure if this holds true with the LS engines.
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
