1.6 Rockers and com durtions......
Old Dec 3, 2003 | 02:11 PM
1BADHD's Avatar
Default 1.6 Rockers and com durtions......
If you add 1.6 rockers to a stock engine. Does that advertantly change the duration of the cam?
Old Dec 3, 2003 | 02:20 PM
Flyer's Avatar
It will shorten it slightly. It will also give a shorter ramp rate and ever so slightly less lift.
Stockers are 1.7
Old Dec 3, 2003 | 02:28 PM
1BADHD's Avatar
So say I got 1.8 or 1.85 rockers. Whatever they are. That will also change the duration?
Old Dec 3, 2003 | 02:29 PM
Yelo's Avatar
why would you go DOWN in rocker ratio ???
Old Dec 3, 2003 | 02:30 PM
1BADHD's Avatar
Its not my question. Someone else asked me and I posted it. I realized the 1.6 was a mistake once I re-read it. I think he meant 1.8.
Old Dec 3, 2003 | 02:40 PM
Hit Man X's Avatar
Apparently a larger ratio will add some more duration, lift, and if they have a roller tip will free up a bit more power there due to the lack of friction.
Old Dec 3, 2003 | 02:44 PM
Flyer's Avatar
I concur ... they will also increase the ramp rate ever so slightly too.
Typically speaking, there are other places to yield better gains than rockers. If you want to make a difference on your valve train, I would go with some Ti retainers and keepers. Maybe a spring change, but if you go with a much bigger spring, better look at pushrods too.
Old Dec 3, 2003 | 10:18 PM
ThunderZ28's Avatar
12 Second Club
the rockers will change the duration of the cam giving the stock cam an ever so slightly lope. as this is what happened when i did mine. gave it a whomp whomp whomp sound. i like it. sounds better than stock but you have to listen for it. i bought the comp cam roller rockers and it did free up a little horse power but the main reason i bought them is that i am planning on changing out the whole valve train to comp. springs, retainers, push rods, keepers, lifters, and of course a cam. 212/218, .522/.529 114lsa to be exact.
SS94S10
Jan 3, 2019 01:57 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
