09 Sierra Cam/Intake/Torque Converter ???
Old Nov 29, 2010 | 08:15 PM
seerysj's Avatar
Default 09 Sierra Cam/Intake/Torque Converter ???
It's been a while since I posted, but I had a couple questions.
1st- Anyone know the stock cam specs on an 09 Sierra SLE 5.3L 2WD with DOD/AFM?
I'm getting ready to do a DOD delete, figured I'd swap the cam out while I'm that far into the motor, just wanted a reference point.
2nd- The Fast LSXRT manifold comes with a 102mm TB inlet, unfortunately the truck has a 90mm OEM (electronically controlled TB). I will be installing this manifold when I put everything back together. Is their a 102mm TB available that is a direct OEM replacement?
3rd- Since I'll be doing a cam swap, where do I find a good stall converter for this tranny? Looking for a 2000-3000 stall, depending on the cam specs of the new cam of course.
Looking forward to hearing some input. Thanks in advance.
Dan Neumann
11
Aug 7, 2022 09:06 AM
GXPJAY
Feb 13, 2022 08:15 AM
LCHEE
Oct 24, 2020 04:10 PM
Slow94Formula
Nov 15, 2015 09:23 PM
darnie
Aug 10, 2015 10:25 AM
