05 GMC 5.3 Exhaust
Old Oct 8, 2005 | 07:44 PM
_Lifted_GMC_'s Avatar
Default 05 GMC 5.3 Exhaust
Ok so I have a 05 Sierra with a 5.3 and 2 1/4'' dual exhaust from the cats back with no mufflers. My question is can you cut out the cats and weld in pipe on this new of a truck? I've heard you couldn't do it after 1995 because it messed up your engine or something and your check engine light stays on.
Old Oct 8, 2005 | 07:54 PM
erronisme's Avatar
need a pair of O2 simulators.
Call Caspers or ask which part numbers at summitracing.com
Old Oct 8, 2005 | 08:06 PM
You are breaking federal law you know
So if caught, be prepared to pucker up and bend over for fed prison
Old Oct 8, 2005 | 08:07 PM
Ya I know I will be but I live in the middle of bumfuck egypt. Closest town is 20 miles and it pop. is 246. Would these work? http://store.summitracing.com/defaul...=egnsearch.asp
Old Oct 8, 2005 | 08:10 PM
StrokerAce03's Avatar
Simulators or a custom tune will fix the SES light. You're losing lowend with the straight duals like that. I had the same setup you have now and lost some lowend. An x-pipe should help it out though. It'll help even out the flow.
Old Oct 8, 2005 | 08:13 PM
I'm not really worried about performance since I have a 6inch lift and 36''s. Also how much mileage will be lost if I do this?
Old Oct 9, 2005 | 08:51 AM
skindog39's Avatar
You can deifinitely weld in a pipe in place of the cats. The only problem you will encounter is that by not having the rear o2 sensors, your engine may run too rich or too lean....causing the engine to run a little rough and the SES light to remain on. The simulators should solve your problem though. I have them and have had no problems.
Old Oct 9, 2005 | 07:26 PM
SBChevrolet's Avatar
iirc it makes you a LITTLE rich not enough to worry about though. I have mine cut out and and noticed a increase in MPG and no loss in power. I do smell the exhaust a little more now though but I hate cats and wouldent put them back on
Bumpers
Aug 4, 2024 09:44 PM
Jake99
Aug 8, 2015 07:56 AM
Three6GMC
Aug 3, 2015 07:53 PM
Chiphead
Aug 1, 2015 04:43 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
