cam for 5.3 z71
Old Oct 8, 2005 | 01:31 PM
00blackz71's Avatar
Default cam for 5.3 z71
I am lifting my 00 z71 and will be running 39.5 swampers. I want to put in a cam and converter for low end power but I have know idea which one to use. Other than thorley headers everything is stock. What would be best for mostly low end torque but also fairly decent top end as well? Anything else I could do that would give more low end?
Old Oct 8, 2005 | 02:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Dont get naything over a 2500 stall speed converter Fuddle makes some good converters but on the cam man I know alittle bit about cams but not enough to really point you in the right direction I would call Comp or Crane or one of the other manufacturers and tell them what you need and they should be able to tell you. FYI you need a custom tune also to make the most of the cam and also will be able to adjust alot of other things to make the truck more driveable give Nelson Performance a call he can hook you up I had him tune my truck and its awesome the difference that it makes. There are other tuners out there but most of the guys that are at the top are either doing their own tuning or have Nelson do their tuning I personally wouldnt trust anyone else.
Old Oct 8, 2005 | 10:01 PM
00blackz71's Avatar
I have been looking into cams others have used: comp 212/218, tr220, vinci 210/218 and 216/224. I know all of these are close but is there one better than the others? Would a yank 2600 be too much stall for my setup? The tr220 says not to use 1.8 rockers and the rest say they work well with the 1.8's. If I use crane 1.8 rockers, whick cam would be best?
Old Oct 9, 2005 | 12:37 AM
FarmerBeau's Avatar
Sexy Party Mod
what are the lifts and the lsa's on those cams?
Old Oct 9, 2005 | 11:12 AM
thunder550's Avatar
High on diesel fumes
I have the Vinci Ultra-Torque cam, recommended to me for excellent low-end and an improved top-end.
Specs are:
210/218-551/551-116
I really like it a lot, and it came alive even more with the 1.8 rockers. If you can afford the whole kit I would definitely recommend it. I think the gross lift increases to .585 or so with the 1.8 rockers.
Old Oct 9, 2005 | 01:36 PM
FarmerBeau's Avatar
Sexy Party Mod
i would imagine that that particular cam would be quiet... is it?
Old Oct 9, 2005 | 02:46 PM
thunder550's Avatar
It is...its got a very subtle hardly noticeable lope to it....the thing that made it really loud was the rockers. I just had a Magnaflow resonator welded in and it helped a lot, but it was really really raspy with the Corsa and gutted cats.
Old Oct 9, 2005 | 08:11 PM
00blackz71's Avatar
tr220 .551 112 or 114
comp 212/218 .522/.529 114
vinci 210/218 .551 116
vinci 216/224 .551 115
Choda
Jan 22, 2026 02:03 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
