05+ efans or ls1 efans
Old Jan 14, 2011 | 07:00 PM
Sn0wBa11's Avatar
11 Second Truck Club
Default 05+ efans or ls1 efans
Torn between the two. If I get the 05+ efans I'll have to get a radiator too but it'll be a clean install since the fans will bolt directly up to pre-existing holes. The ls1 efans will fit my current radiator but I will have to build brackets to mount them and such resulting in a not so clean install. I really want the 05+ setup since it's a factory stock setup but the ls1 fans will be much more affordable.
Just wanting some opinions guys, Thanks
Old Jan 14, 2011 | 07:15 PM
RibeiroBJJ's Avatar
Praise The Lowered
Neither..get the flex-a-lite 292's...They are 28" wide and install like factory...
Old Jan 14, 2011 | 07:58 PM
Sn0wBa11's Avatar
Those are nice but they are definitely expensive
Old Jan 14, 2011 | 08:14 PM
charcoal03silvy's Avatar
Ls1's will do the same job as 05+
From everything I've read, don't go with after-market fans
Old Jan 14, 2011 | 08:38 PM
RSTinOKC's Avatar
Or check out Trick e-fans...click on the banner over there ---->
Old Jan 14, 2011 | 08:55 PM
Heard nothing but great about those. I've heard flex-a-lite and others are
Old Jan 14, 2011 | 09:18 PM
Luke03's Avatar
Had flex a lite efans on mine and ended up selling them. Didn't get the job done for the price.
Went to the 05 radiator/efans and even on these hot 100*+ days in texas it never overheats and with the tru cool 40k cooler the transmission never gets over 130*. Well worth the upgrade.
Old Jan 14, 2011 | 09:29 PM
CashDudeHomie's Avatar
I ran the LS1 fans for a while, but switched to the 05 fans and radiator when I had the money. Either one will work, but the 05 fans are a lot larger. Just get a 3 relay wiring harness with fuses so you can wire them up to properly and safely run controlled by the PCM.
Old Jan 14, 2011 | 11:42 PM
Sn0wBa11's Avatar
Just checked out the trick efans and liked what I seen. Price seems very fair too. I wonder if they can be wired up the same way as the 05+ efans using the harness from Nelson or BlackBear to work off of the pcm?
Old Jan 15, 2011 | 12:25 AM
pewterliftedz's Avatar
yes they can, when you call up nelson to order a harnes they will ask what fans they are for. just tell them universal..
