05 5.3 gmc sierra knocking or ticking
Old Jan 1, 2019 | 08:58 AM
4.8hemieater's Avatar
Default 05 5.3 gmc sierra knocking or ticking
Ok so I just pulled up to autozone and parked with the truck slightly up hill, while sitting here for 5 min the motor started making what sounds like a lifter tick. I backed up and parked and now the nose of the truck is angled downhill and the ticking got quiet and now went went away. Oil pressure at 30psi at idle. Any ideas?
Old Jan 1, 2019 | 09:20 AM
trxmxzx's Avatar
13 Second Truck Club
How many miles on your oil?
My wifes truck does this..... higher mileage on oil at idle will be 25ish- fresh change will be 40 at idle till 2500miles or so
it’s gets louder as the oil breaks down
Old Jan 1, 2019 | 09:29 AM
it just had an oil change 160 miles ago because they fix the oil pan gasket leak. It only does it on uneven surfaces but a cold start up on level ground it is fine
Old Jan 2, 2019 | 09:14 AM
RedXray's Avatar
100% Redneck
That's kinda of odd if it's a lifter, maybe it's an exhaust leak at the manifold and the weight shift of the exhaust makes it sound worse?
Old Jan 2, 2019 | 09:21 AM
yea on flat ground it's fine it's just when its uneven it happens hot or cold. Idk I cant seem to find anything like it
Old Jan 2, 2019 | 09:38 AM
BudRacing's Avatar
What's the oil level like?
Old Jan 2, 2019 | 09:59 AM
its right on the full line. 6 quarts and a pf46 filter
2500HD8.1
Mar 10, 2020 03:30 PM
cadmaro
Dec 18, 2017 01:00 PM
adrian_14nk
Oct 10, 2012 04:37 PM
Hemi Killer
25
Mar 20, 2003 12:49 AM
