05 5.3 gmc sierra knocking or ticking
Ok so I just pulled up to autozone and parked with the truck slightly up hill, while sitting here for 5 min the motor started making what sounds like a lifter tick. I backed up and parked and now the nose of the truck is angled downhill and the ticking got quiet and now went went away. Oil pressure at 30psi at idle. Any ideas?
How many miles on your oil?
My wifes truck does this..... higher mileage on oil at idle will be 25ish- fresh change will be 40 at idle till 2500miles or so
it’s gets louder as the oil breaks down
it just had an oil change 160 miles ago because they fix the oil pan gasket leak. It only does it on uneven surfaces but a cold start up on level ground it is fine
cadmaro
Dec 18, 2017 01:00 PM
Hemi Killer
25
Mar 20, 2003 12:49 AM
