03 145A Alt on a 99-02 5.3
Old Oct 27, 2004 | 05:14 PM
creederado's Avatar
Default 03 145A Alt on a 99-02 5.3
I have got an 145A alt (available on 03-04 Silv) on the way
Considering GM didn't offer the 145a Generator on the 99-02 5.3 Trucks,
Any differances with the wiring in the back?
The pulley I measured on my 1999 105a is approx 2 3/8.
Who has done the upgrade??
Thanks.
Old Oct 27, 2004 | 06:20 PM
one03sierra's Avatar
Formerly one92rs
Talking
i went to a 130 off an escalade. all i had to do different was get the belt for that application. hell mine plugged right in and worked perfect.
Old Oct 27, 2004 | 08:09 PM
creederado's Avatar
cool thanks,
I have see what the new belt would be,
everything is stock except the underdrive asp crank pulley.
I'll wait and see when the alt comes in and measure the pulley.
Old Oct 28, 2004 | 12:08 AM
BlownAlaskan's Avatar
Just out of curiousity, was it a shorter or longer belt.. and by how much?
Old Oct 28, 2004 | 05:43 AM
Formerly one92rs
Talking
tiny bit longer
i have a little bit smaller pully on the alt and was able to use the set belt for the asp pullie.
Old Oct 28, 2004 | 03:21 PM
creederado's Avatar
Ok I just got the new generator,
The pulley is the same size but if you line up the mounting holes with the 105 a it sits approx 3/8 higher.
I called ASP and they have a listing for a belt 1/2 longer gates KO6O900
This belt happens to be the belt for the crank and bigger alt pulley kit so it makes sense.
I'm going to try the belt I have on there now first. I have the ud crank pulley belt.
Does Goodyear make the gator belts for our trucks with the ud pulley?
Old Oct 29, 2004 | 07:16 PM
creederado's Avatar
ttt for onyx
gm part # 10464476 145a
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
pewter00
Sep 7, 2015 10:14 PM
