02 sims question
Old Oct 11, 2003 | 01:33 AM
02chevyracing's Avatar
14 Second Truck Club
Default 02 sims question
will a fbody type sim work on our trucks?
Old Oct 11, 2003 | 04:22 PM
eallanboggs's Avatar
Default Re: 02 sims question
You have to be sure to get the ones that have the same color connector as you currently have. There are grey and black types and the keys inside of the connectors are NOT the same so the are not interchangeable. If you could plug them in they'd work because the wiring is the same, but they used a connector with a slightly different key on the inside of the connector. Check yours to be sure BEFORE you order.
Old Oct 11, 2003 | 10:27 PM
z7199's Avatar
you have to have a fast truck to need these and since I have won every race I would not suggest doing any exhaust work because you will always be slow punk!!!!02 chevyracing you should rename 02slowverado
Old Oct 11, 2003 | 10:29 PM
F U Z7199 YOUR TRUCK IS A P.O.S!!!!! YOU CALL ME TO FIX IT EVERYDAY. MAYBE I SHOULD START CHARGING YOU!!
JordanH
Dec 25, 2015 08:32 AM
6.0l RST
Nov 23, 2015 11:30 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
