02 HD Turbo Update Weeks worth of Driving
Old Jun 23, 2005 | 08:37 AM
NXRICKY's Avatar
Former Vendor
Default 02 HD Turbo Update Weeks worth of Driving
Weeks worth of driving and so far found a couple of tweak that need to happen. The down pipe is real close the frame and under a extreme lunch or heavy load likely hood of bumping it is to high.(SO) it will need to moved and or a simpe notch created in the pipe. Lets face it 3.5 pipe is a little over kill for a stock truck.
Radiator over flow, tank. I installed a 90' fitting to get away from compressor side but it now leaks so into the trash and new one is on the way. Heat so far is not an issue the stock fan moves tons of air, and been running normal temps so far. 185-205 and its been 98F+ while doing most of the testing. Also that DEI heat sheilding is bad *** stuff, covered the a/c hose, a piece of the brake line and heater hoses, and damm that stuff just does not get hot. After a 30min cruise in stop and go traffic, I could touch that stuff and not even hot. pretty cool.
The 4" ubends got to go, to heavy and no need so it will be knocked down to a 3" stainless pipe. The 4" kept blowing the hoses off, so I put a couple of beads on the pipe, and still had one pop. The weight must just be pulling on so hard while driving. Lets face it a 2500 does ride like a Cady.
Also the water drip from the a/c land right ontop of the down pipe. Now I know this is no biggy but man sound crapy after you stop get out and you hear hiss, hiss, hiss. Going to reroute the drip hose. It is just anoying.
I am still waiting on my tuning software/scan tool and my custom fuel plate/water meth kit to show up to put this on the dyno and see what power level it will get to. (and hoping the with water meth no more I/C) Truck is real peppy but I am not going to slam Wide Open until I can see whats up. I did get a check engine light on after 4 days of driving not sure what that is, I guess the software will tell me...
And one final note, even though I have not slammed the throttle, I can hear and fell the turbo starting to work at a nice 1800-2200, and that just with cruising. Turbos just sound cool .
More Updates to come after I get to tune this up and get it on the dyno.
Ricky
Old Jun 23, 2005 | 08:59 AM
14 Second Truck Club
Dude, your truck is nice. Keep us updated with any performance numbers too.
Old Jun 23, 2005 | 10:00 AM
NXRICKY's Avatar
Former Vendor
Thanks for the compliment. I plan on trying to update ever week to two. Anyone know a REAL number the 6.0 can handle all day long, or is it going to be the transmission that is going to fly apart. Friend of mine told to stay under 10psi and it should live a long time.
Ricky
Old Jun 23, 2005 | 10:09 AM
bud8fan's Avatar
great job on the setup...keep us updated on the numbers
Old Jun 23, 2005 | 04:49 PM
BigBlockChev572's Avatar
Ricky
Parish8 ran 16 PSI of boost on his T76 consistently throught many street races and tons of track runs. I'm sure he'll chime in. The 4l80e should not crap out on you under 15PSI IMO without crazy launches and stuff.
Philip S.
Old Jun 24, 2005 | 09:17 AM
NXRICKY's Avatar
Former Vendor
Philip S.
Will the final number I am looking for is 10-12 psi daily driver, I can hook up to a trailer and haulass to whereever I need to be. The fuel plate and water meth are due next week. And scanning software???? Anyway pipeing is changing to 3". Going to be busy this weekend lol.
Ricky
Old Jun 24, 2005 | 09:05 PM
BrianGallimore's Avatar
what type of water injection system are you going with?
Old Jun 24, 2005 | 09:20 PM
NXRICKY's Avatar
Former Vendor
A new company coming onto the seen in the water meth stuff. I have the demo soft ware and the beta unit with my fuel plate is due here next week. I do not have the companies permission at this time to say who it is. But, the programming screen looks more like a fuel managment system, total water control with a couple of maps to go off of, like map vs rpm, tps vs map, changing cells up and down then review in the 3D world to make sure there is not any spike that look funny. You can also change the RPM levels across the board, to me its pretty wild. 140-200psi injection, solenoid controled water flow, so under normal driving no water getting sucked into the intake. I am sorry I can not give all the details but as soon as the beta is here and I get the green light, I will be posting picks of the screens and the results. I am hoping to be able to get rid of the Inter cooler with it.
Ricky
Old Jun 25, 2005 | 10:57 AM
Ricky
Yes, a busy weekend indeed!
Philip S.
Old Jun 25, 2005 | 11:09 AM
bud8fan's Avatar
yep...very busy...keep us updated...
LCHEE
Oct 24, 2020 04:10 PM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
