02-04 stock cam size?
Old Mar 18, 2005 | 08:24 AM
98TAauto's Avatar
Default 02-04 stock cam size?
anyone know if the 5.3's all cam with the same size cam?
if so, whats the specs?
looking to see if its worth slapping a 01-02zo6 cam in there. If anyone's done so.. how id daily driving? Note, this truck needs to make 2 hour trips with no issues
Old Mar 18, 2005 | 08:32 AM
FILE's Avatar
Slapping an ls6 cam in there is worth about 30rwhp. I would personaly do an 01 ls6 instead of an 02+. This cam should idle just like your stock cam.
Old Mar 18, 2005 | 08:36 AM
98TAauto's Avatar
thanks for the info.. what are the specs on the 01 ls6 cam compared to the 02+ 5.3; cams?
Old Mar 18, 2005 | 08:43 AM
FILE's Avatar
Can't recall them now but I do know with the 01 ls6 cam, you won't loose as much low end compared to the 02+. This is why many people suggest going with the 01.
Old Mar 18, 2005 | 08:55 AM
98TAauto's Avatar
how about tuning wise with that cam? I have ls1edit for my car and will probably get it for the truck, but would everything do fairly well for awhile without the tune?
Thanks for the help also
Old Mar 18, 2005 | 09:13 AM
98TAauto's Avatar
http://www.ls1truck.com/reference/oemcam.htm
found the cam specs.. i take the 01ls6 cam would be a good choice without a stall correct?
just looking for some top end without to much low end loss
Old Mar 18, 2005 | 09:36 AM
fluxu8's Avatar
I'd like to know also....as far as tuning goes.
Part# for the 01 is 12560950...$200 off gmpartsdirect ain't bad.
WICK3DxGATA
Jul 21, 2015 06:59 PM
bsn1989
Jul 16, 2015 08:20 AM
4B11T
Jul 13, 2015 03:48 PM
kdw8888
Jul 9, 2015 10:52 PM
jrplz
Jul 9, 2015 12:07 AM
